Post by jeffareid on Sept 25, 2009 15:38:56 GMT
Now that I think about it, Ambush Canyon has a few bumps that mess up the works Z06 a bit, more so the works Camaro SS. Assists may help with the bouncy response. I found that I had to memorize where the bumps were and veer inwards a bit before those bumps so that the car "landed" back on the normal line.
Post by jeffareid on Sept 25, 2009 17:05:33 GMT
I forgot to ask. Does using manual clutch allow faster shifts the way it did for ProStreet?
Post by VGSpeedPro on Sept 25, 2009 18:02:21 GMT
Auto Clutch Off allows better car control, which probably means faster lap times, especially due to time we win in breaking. Nonetheless, Clutch Off also has a downside: if you spin or you crash and the car goes to neutral, you will be stuck in full stop for several seconds...
Post by Grnkjr0 on Sept 26, 2009 1:59:05 GMT
Ok! I will give it a try, thanks! Rogério When you have beaten Luca with Mazda MX-5 I will look into this. Not until then will I give this another try. Poul
Post by jeffareid on Sept 26, 2009 7:05:28 GMT
With ABS off, the Murc can brake faster. Seems it's better to run the Murc with all assists off. My best laps are around 1:55.3 now, in normal or experienced mode. The grip levels would appear to be based on the gameplay mode. In the file physicsbootflow.bff, there is another file physicstweaker.xml, and in that I see the line:
<prop name="grip level" data="1.45;1.3;1.3;1.2" />
I assume that the multipliers correspond to the game modes:
1.45 - casual 1.30 - normal 1.30 - experienced 1.20 - pro
Post by jeffareid on Sept 26, 2009 12:35:13 GMT
I did a run in normal mode, auto clutch off, for a 1:54.910 lap. I've only run a few laps under 1:55, so I think I've reached my limits. Maybe VGSpeedPro can look at the video and see where I could improve. www.youtube.com/watch?v=oAyN9PZgEoE&fmt=22
Post by tcrluca (PC) on Sept 26, 2009 14:00:35 GMT
hey jeff.. i have the same problem.. you have digital copy? i have it.. but with DVD Copy work good..
Luca
Post by VGSpeedPro on Sept 26, 2009 14:53:22 GMT
I did a run in normal mode, auto clutch off, for a 1:54.910 lap. I've only run a few laps under 1:55, so I think I've reached my limits. Maybe VGSpeedPro can look at the video and see where I could improve. www.youtube.com/watch?v=oAyN9PZgEoE&fmt=22Hi my friend! I saw your Lap and I didnt saw anything wrong with it... I take a little more inside line on some corners... Probably the difference is the braking and eventually some extra speed I take into cornering entry... I will try to save a video... Rogério
Post by tcrluca (PC) on Sept 26, 2009 15:23:11 GMT
i try DVD copy without set 1,53,09.. 290kmh is a beast.. i think with set can do 1,50 1,49 easy.. monday im back and make default&set video.. see you guys..
Luca
Post by jeffareid on Sept 26, 2009 20:29:09 GMT
As VGSpeedPro mentioned in another thread, the Zonda R is faster. I ran a 1:54.1 after a few laps. Turning off autoclutch on the Zonda makes the gear changes jolt the car, so I turned it back on. I left downforce alone, but changed the gearing to get the gears closer: 1st - 1 click right 2nd - 1 click right 3rd - middle 4th - 1 click left 5th - max left 6th max left The car redlines in 6th, and makes an awful sound, but it continues to accelerate to about 188 mph = 300 kph, depending on the track. I usually set the damper fast rebound rate to max right to reducing bouncing on some cars (works Camaro SS). The Zonda R probably doesn't need it, but it shouldn't hurt either. The settings will end up one click left of max right due to a setup bug in Shift. In Shift, no advanced tuning setup parameter can be set to max right, as it will revert to one click left of max right once you leave the tuning menu. I bought the NA (North American) DVD version of Shift from a local store. I don't know if the European version is different. The console version is faster. Some one posted a 6:16.4 run at Nordschleife using works Z06 on a PS3: www.youtube.com/watch?v=LEh1OG0Fm58
