Post by rcgldr on Oct 27, 2010 11:51:31 GMT
Downtown Rockport, Fortuna, Kempton areas opened. Some connector roads not opened yet.
I only found 24 new tracks (release notes mention 25). I only found 1 new track in an old area, Camden Hills (3 laps)
Most Wanted tracks:
Camden Hills Financial District Hastings Lions Challenge Little Italy Riverfont & Green (as spelled on map in game) Seaside Interchange Valley & State West Park & Forest West Park & Lyons
Carbon Tracks:
Agostini Avenue Beachfront Central Coast Dover & Lepus Dover Street Kempton Docks Mission Street North Bellazza Petersburg Dam Skyline Avenue University Way Verona Tunnel Waterfront Road York Road
Post by rcgldr on Oct 27, 2010 11:58:31 GMT
Multi-posting to keep sub-topics separate. In Bound changes:Pursuit music changed - I liked the original version better. Rosewood Bus Terminal - barrier blocking busses, if you get past it, car falls down into corner of nearest bus. The other ramp still works the same as before. Cooldown spot west of Beacon & Station. Fake wall now shows as breakable boards. The view spot on other side now has small posts (no change to barrier there). Airport terminal road - A third loop was added to the double loop at the west end of downtown Rockport. The signs on the building on hwy 142 now show Palmont University - Badrock Geophysical Observatory - BGO. It use to show Municipal Transport Taskforce - MTT. The dam near hwy 142 is slightly larger and has some water running out of small ports. I liked the early beta version, which was eseentially the Carbon version which was bigger still and had large amounts of water flowing out of it. Halloween theme in many place, but not permanent. Out of bounds changes (will post pictures later)Beach house is back and updated (big screen TV, fireplace). Original safehouse is updated (window and lights on). Most of the Rockport Turnpike (mystery bridge) is driveable. The connector road between downtown Palmont and downtown Rockport is no longer drivable. A lot of cityscape is rendered near it. Former version that was drivable: rcgldr.net/nfsw/nwfloatroad.wmv
