Hey all
I had hoped my new GTX 460 graphics card would have arrived Friday, so that I had the weekend to test things - well now it is here. It is not that big compared to my GTX 285 - good news for those without a really large PC case.
I have not had much time to test it and how much it can overclock, but I would say it performs about the same as my GTX 285, but it overclocks a whole lot better and when overclocked it is some what faster than my GTX 285 - which does not overclock as much as this GTX 460.
Here is a screen shot of the GTX 460 in GPU-Z - not bad numbers if you ask me. The default numbers are core clock: 675MHz shader clock: 700MHz and memory clock: 900MHz. I am currently running - core clock: 900MHz, shader clock: 900 MHz and memory clock: 950MHz.
I tested in Shift at London River (max graphics setting), trying to do lap times around 1.09 to 1.11 and I think the numbers speak for themselves. I do not know how much I can overclock the GTX 460, but I will try later today and max it out with added voltage.
I would say the GTX460 is about 10% faster than my GTX 285 when both are overclocked - not sure yet though. Here are the differences in fps when doing lap times at London River.
Overclocked GTX 285 running 741 core 1600 shader 1403 memory - default 648 core - 1476 shader - 1242 memoryBenchmark at London River time attack in 1.10
2010-07-22 18:27:12 - SHIFT
Frames: 6708 - Time: 79525ms - Avg: 84.351 - Min: 71 - Max: 99
2010-07-22 18:32:56 - SHIFT
Frames: 6669 - Time: 79821ms - Avg: 83.549 - Min: 70 - Max: 98
2010-07-22 18:35:26 - SHIFT
Frames: 6580 - Time: 78769ms - Avg: 83.535 - Min: 69 - Max: 98
2010-07-22 18:38:34 - SHIFT
Frames: 6629 - Time: 79369ms - Avg: 83.521 - Min: 70 - Max: 98
010-07-22 18:43:26 - SHIFT
Frames: 6556 - Time: 78524ms - Avg: 83.490 - Min: 69 - Max: 99
The 5 lap times were within 1 second.
Stock speeds on my GTX 285 2010-07-22 18:51:08 - SHIFT
Frames: 5896 - Time: 78786ms - Avg: 74.836 - Min: 63 - Max: 88
2010-07-22 18:56:03 - SHIFT
Frames: 5900 - Time: 78560ms - Avg: 75.102 - Min: 61 - Max: 88
2010-07-22 19:06:37 - SHIFT
Frames: 5836 - Time: 78124ms - Avg: 74.702 - Min: 62 - Max: 87
2010-07-22 19:09:52 - SHIFT
Frames: 6048 - Time: 80570ms - Avg: 75.065 - Min: 60 - Max: 89
2010-07-22 19:12:13 - SHIFT
Frames: 5779 - Time: 78110ms - Avg: 73.985 - Min: 58 - Max: 88
Out of the box GTX 4602010-07-26 16:05:34 - SHIFT
Frames: 6504 - Time: 83479ms - Avg: 77.912 - Min: 57 - Max: 92
2010-07-26 16:07:13 - SHIFT
Frames: 6729 - Time: 85204ms - Avg: 78.975 - Min: 69 - Max: 92
2010-07-26 16:10:35 - SHIFT
Frames: 6254 - Time: 79452ms - Avg: 78.714 - Min: 65 - Max: 92
2010-07-26 16:12:13 - SHIFT
Frames: 6279 - Time: 80004ms - Avg: 78.484 - Min: 68 - Max: 92
2010-07-26 16:13:44 - SHIFT
Frames: 6353 - Time: 81006ms - Avg: 78.426 - Min: 62 - Max: 92
Overclocked GTX 460 - 900 core - 900 shader - 950 memory2010-07-26 16:55:41 - SHIFT
Frames: 7190 - Time: 78107ms - Avg: 92.053 - Min: 80 - Max: 106
2010-07-26 16:57:10 - SHIFT
Frames: 7175 - Time: 77677ms - Avg: 92.370 - Min: 80 - Max: 106
2010-07-26 17:00:48 - SHIFT
Frames: 7317 - Time: 77992ms - Avg: 93.817 - Min: 81 - Max: 107
