Post by paul on Aug 18, 2012 11:26:27 GMT
Interesting review, Poul! If Xbitlabs do this job for long time and they testing with consistant methods, I have no problems to believe their measured results. I thought the H100 is better than this Antec because of the larger radiator.
For OC'd i7 950 I would go with Noctua NH-U12P SE2, its cheaper than D14 and it will do this job just fine (for OC to 4.2GHz). Also depends a lot on the thermal compound and if the base is flat. Giants like Thermalright Silver Arrow or Phantec PH-TC14PE are good for extremely clocked CPUs and they aren't so friendly to the motherboard, with weight around 1.5kg. I'll be affraid of damage in longer use.
Paul
Post by TheGreenMonster (PC) on Aug 19, 2012 14:44:17 GMT
Cheaper is not necessary better....You get what you paid for... this Antec 920 keeps my CPU at a cool 50 C. at OC 3.8 Ghz I could go higher but I need a new mother board... My USB controller sort of died on my current mother board... I am thinking of getting a USB controller card.. and get a new mother board later on.... check out this review on my liquid cooler Interesting review, Poul! If Xbitlabs do this job for long time and they testing with consistant methods, I have no problems to believe their measured results. I thought the H100 is better than this Antec because of the larger radiator. For OC'd i7 950 I would go with Noctua NH-U12P SE2, its cheaper than D14 and it will do this job just fine (for OC to 4.2GHz). Also depends a lot on the thermal compound and if the base is flat. Giants like Thermalright Silver Arrow or Phantec PH-TC14PE are good for extremely clocked CPUs and they aren't so friendly to the motherboard, with weight around 1.5kg. I'll be affraid of damage in longer use. Paul
Post by TheGreenMonster (PC) on Aug 21, 2012 1:58:54 GMT
After further reveiw, a USB controller card is not going to work for me...So I've checkout a few mother boards... tell me what kind you like?? Poul and Paul......and who ever else....... ASUS Rampage III Gene LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard www.newegg.com/Product/Product.aspx?Item=N82E16813131658
Post by paul on Aug 21, 2012 8:20:39 GMT
Ok Sunny, you have now great CPU cooler and I assume you will want push your CPU a bit above 3.8GHz. This means you need motherboard with massive heatsings on the power delivery cascade. This Asus ROG you've posted looks really good, but its a mATX motherboard - I don't know how many PCIe and PCI based components you will plug into. Usually I suggest ATX boards, but if its not really necessary, the mATX is good choice with enough slots for typical PC user. I'm not sure of the quality of MSI or Gigabyte boards for the LGA1366, it may be no less than Asus, but I've heard about problems with BIOS. Furthermore I've seen many happy owners, so I assume it will be not that hot. I think this can be the alternative: www.newegg.com/Product/Product.aspx?Item=N82E16813131715www.newegg.com/Product/Product.aspx?Item=N82E16813128472The Gigabyte Assassin is pricey, but I see a lot of potencial in OC on this one. You pay for the Quad SLI possibility mainly, which is, I bet, absolute overkill for your needs. The Asus Rampage III Gene may be the best choice for you. Paul
Post by TheGreenMonster (PC) on Aug 22, 2012 2:43:15 GMT
I have this mother board in my PC now.... except the USB controller failure issue... but there's a work around to keep it running good...but I have to apply the tweek every time I start it up... only takes 2 mins to adjust the USB ports.... www.newegg.com/Product/Product.aspx?Item=N82E16813128413
Post by paul on Aug 22, 2012 8:37:23 GMT
This particular motherboard can have some issues I've mentioned before - Gigabyte boards had problems with BIOS. If you can set the USB ports through the software way, it gotta be a BIOS issue. Did you tried download the latest BIOS version? If not, try it, it may solve this problem. Well, I'm really not sure what else it can be, lets wait for Poul, see what suggestion he has Aside from this, did you ever noticed some dropdowns in CPU voltage? I have old Gigabyte motherboard and when is the CPU under load, it drop by a 0.03V from the vaule in BIOS. I use OCCT software to check it. Paul
Post by TheGreenMonster (PC) on Aug 24, 2012 0:37:34 GMT
This is my error after the PC boot's ....If I don't correct the problem by appling the tweek... the PC blue screens on shut down... My tweek is un-stalling the failed USB port and reinstalling them....take 30 seconds to fix...
Post by TheGreenMonster (PC) on Dec 5, 2012 4:06:15 GMT
My 80 GB Intel SSD is full and I am thinking of getting a 250GB SSD drive,,, has anyone ever swap the data and move all the data to there new hard drive?? Where the new drive boot up with all the data in tack...
What software do I need to get before I buy the new SSD drive...
I don't want to reload everything all over again..
Post by Grnkjr0 on Dec 6, 2012 1:50:06 GMT
My 80 GB Intel SSD is full and I am thinking of getting a 250GB SSD drive,,, has anyone ever swap the data and move all the data to there new hard drive?? Where the new drive boot up with all the data in tack... What software do I need to get before I buy the new SSD drive... I don't want to reload everything all over again.. Likely there will be a software program included that will allow you to clone your current ssd to the new one. Otherwise here is a program that is free, and people say is easy to use: www.extend-partition.com/free-partition-manager.htmlPoul
Post by TheGreenMonster (PC) on Dec 7, 2012 1:27:33 GMT
Thanks Poul, I hope the data tranfer goes smooth, I bought a Intel 240 GB SSD... I installed MS Office 2010 and I installed it onto my d:\drive a 1TB drive but it installed a additional 20 GB to my C:\drive 80GB SSD which fill up the drive... www.newegg.com/Product/Product.aspx?Item=N82E16820167128
Post by TheGreenMonster (PC) on Dec 8, 2012 2:54:42 GMT
MY G25 wheel just died..... damn it.... I bought it on CHristmas 2006 it lasted 6 years......So I just bought a new G27 for $259.00 with free shipping...... Just bought the new 240 GB SSD drive yesterday and a new wheel today......Merry Christmas to all ...even me www.newegg.com/Product/Product.aspx?Item=N82E16826104330
Post by Grnkjr0 on Dec 8, 2012 5:17:42 GMT
Sunny, Merry Christmas to you too ..... Poul
Post by TheGreenMonster (PC) on May 29, 2013 0:19:32 GMT
Post by aarog5606 on May 29, 2013 2:11:24 GMT
If you can afford the 670, definetly get that, one of the best cards, for the money, available. Overclocked, it has very close to same benchmarks as the 680, for alot less money. I have the 660ti and it is also a great card. Now that i overclocked it as high as i want to go, i can play BF3, Bioshock and Far Cry3 on on high and get anywhere from 80 to 100+ fps. But that 670 is a beast overclocked or not.
Post by Grnkjr0 on May 29, 2013 3:39:16 GMT
I wonder what it will take to play Grid 2 in 120+ fps? Not much fun in having a 120 Mhz monitor, if I am not getting that kind of fps with my current hardware. Poul
