Post by Jussi on May 15, 2010 1:28:07 GMT
What's wrong in this picture? That's right... 2 out of 4 racers are using "stealth mode". Jussi
Post by TheGreenMonster (PC) on May 15, 2010 1:47:24 GMT
What names are you guys using this time? I have the same name as last 3 beta... TGreenMonster ,,,
please post your name....
Post by Deleted on May 15, 2010 2:51:29 GMT
You should know mine.
Post by Deleted on May 15, 2010 2:53:28 GMT
Post by TheGreenMonster (PC) on May 15, 2010 4:35:53 GMT
Man I'm having much luck with this beta, I don't have any NOS or jaggernaught and I can't figure out how to get them. I can't find any racer online in order to race. It might take 500 single player races in order to make enough money to get anywhere.
Since my first race with the cop chase where and I took out 81 cops. I've increase my heat level to 6, once the SUV are called in it's all over with for me, no NOS no Jaggernaught, Im history.
Post by Deleted on May 15, 2010 4:51:23 GMT
Man I'm having much luck with this beta, I don't have any NOS or jaggernaught and I can't figure out how to get them. I can't find any racer online in order to race. It might take 500 single player races in order to make enough money to get anywhere. Since my first race with the cop chase where and I took out 81 cops. I've increase my heat level to 6, once the SUV are called in it's all over with for me, no NOS no Jaggernaught, Im history. I've yet to even race this time around, literally did nothing but pursuits. I hardly use nos, and don't use juggernaut in pursuits. My trick with the SUV's is if there are cops right behind me swerve at the last second or if no cops behind me at the moment. let them hit then go in reverse and spin the car around and alter your course. Also @ your skill level, get the charger if you are wanting a car to do pursuits with in this game. Save the other cars for the races.
Post by Jussi on May 15, 2010 6:25:07 GMT
I'm Jussi in the game too.
Post by Velocity on May 15, 2010 7:22:05 GMT
my comp wouldn't let me play (kept going on "Not Responding") so I went in Most Wanted to get pics for my [NFS Story] at least... @nfsworld "Not Responding", my comp's physical memory before launch was around 20-30ish, but at the "Not Responding" I noticed it above 50... meh, I'll try again later ... and no I can't delete anything more off my comp nor do I have any external harddrives n stuff (I'd need one that could hold a few GBs... dont have the money either)
Post by MadMustang (Xbox, Wii,PC) on May 15, 2010 8:30:53 GMT
Not working either Velocity. Same as before just doesnt boot up properly. Its at exactly the same point as before. Madster
Post by aarog5606 on May 15, 2010 11:27:37 GMT
I tried to play for a few last night, but couldnt get my wheel to work at all. Couldnt run at 1920x1080 resolution either, 1650x?? was the highest i could go.. In fact i restarted the game several times trying to get the wheel to work and it kept resetting res. to 1024x768? Graphics looked pretty decent though.
Post by Jussi on May 15, 2010 13:35:19 GMT
Not working either Velocity. Same as before just doesnt boot up properly. Its at exactly the same point as before. Madster There's couple of points where the launcher seems to hang, but it continues for me if I wait long enough. Make sure the game and PnkBstr have required internet access passes though. Jussi PS. And please send bug report to EA so they know what to fix.
Post by Bandit (PC/PS3/4) on May 15, 2010 14:50:06 GMT
Looking good so far .. Just got 8000 off a 32 minute chase!
Post by TheGreenMonster (PC) on May 15, 2010 17:24:20 GMT
To Velocity & Madster you guys might need to open up your ports setup 1; located your network card right click and goto properties then click advance tab,,, u should see firewall. then click on exceptions exception if you don't see NFS WO then click on add program and just point to the wo folder next add TCP port 12683 then click OK Add UDP port 31928 then click OK hope this helps
Post by spiko on May 15, 2010 18:03:46 GMT
Pursuits is the only thing I did for this beta session. I did about 10 and I got busted 2 or 3 times (good ones). To lvl 5 couple to lvl 7 that includes this bust Than I Kasper made a good suggestion to use the charger and I did but got busted again to lvl 16 is this one couple more within lvl 16 and this one to max lvl 20 I don't know why has more rep reward points here and with the cash reward has different I don't know if it will be the same way when the game goes live, but if it does pursuit will be the quick way to lvl up. Also i see that you get less cash with a better pursuit. Spiko PS I guess something for my friend Sunny to chase also
Post by TheGreenMonster (PC) on May 15, 2010 18:29:59 GMT
Da*n Spiko .... 124 cop car take out.... I don't see me beating that, If only I can get enough money for the charger I might still have a chance...... Everytime I get busted it cost me 1,600 bucks.... So congratulation to Spiko with a 124 cops so far...
