Post by aarog5606 on Mar 1, 2010 0:50:50 GMT
2:01.340 - Cipriani - Zonda R - 20.50 - 15pts 2.01.810 - Grnkjr0 - Zonda R - 20.50 - 14pts 2:01.970 - KhekZ - Zonda R - 20.50 - 13pts 2.02.610 - rtxus - Zonda R - 20.50 - 12pts 2:03.750 - aarog5606 - Zonda R - 20.50 - 11pts 2:03.980 - Roughneck - Pagani Zonda R - 20.50 - 10pts 2:04.220 - TomasT - Zonda R - 20.50 - 9 pts 2:04.700 - Fishy - Zonda R - 20.50 - 8 pts 2.05.130 - Dreamgate - Zonda r - 20.50 - 7 pts 2.05.350 - Spiko - Zonda R - 20.50 - 6 pts 2:06.960 - TheGreenMonster - Zonda R - 20.50 - 5 pts 2.10.810 - Sesfontain - Lamborghini LP640 - 20.99 - 4 pts 2:13.680 - Bandit - Pagani Zonda R - 20.50 - 3 pts 2:18.380 - RicardoElfrinko - Maserati MC12 GT1 - 20.00 - 2 pts 2:24.350 - jsskppnn - Pagani Zonda R - 20.50 - 1 pts Congrats Norman!
Post by aarog5606 on Mar 1, 2010 1:07:12 GMT
Febuary Leaderboard: FINAL DRIVER | 6.00 | 10.00 | 14.00 | Unrest| TOTAL | RANK ----------------+-------+-------+-------+-------+-------+------------- Grnkjr0 | 8 pt + 7 pt + 13 pt + 14 pt = 42 pt | Professional aarog5606 | 6 pt + 8 pt + 11 pt + 11 pt = 36 pt | Professional xXxH0TRIDExXx | 7 pt + 9 pt + 10 pt + 0 pt = 26 pt | Professional rtxus | 0 pt + 0 pt + 12 pt + 12 pt = 24 pt | Professional Cipriani | 0 pt + 0 pt + 0 pt + 15 pt = 15 pt | Professional VGSpeedPro | 0 pt + 0 pt + 14 pt + 0 pt = 14 pt | Professional Khekz | 0 pt + 0 pt + 0 pt + 13 pt = 13 pt | Professional - TomasT | 5 pt + 0 pt + 7 pt + 9 pt = 21 pt | Semi-Pro Spiko | 0 pt + 5 pt + 8 pt + 6 pt = 19 pt | Semi-Pro Bandit | 3 pt + 6 pt + 6 pt + 3 pt = 18 pt | Semi-Pro TheGreenMonster | 4 pt + 4 pt + 5 pt + 5 pt = 18 pt | Semi-Pro
- Fishy | 0 pt + 0 pt + 9 pt + 8 pt = 17 pt | Clubman RicardoElfrinko | 2 pt + 3 pt + 3 pt + 2 pt = 10 pt | Clubman Roughneck | 0 pt + 0 pt + 0 pt + 10 pt = 10 pt | Clubman - Sesfontain | 0 pt + 0 pt + 4 pt + 4 pt = 8 pt | Rookie Dreamgate | 0 pt + 0 pt + 0 pt + 7 pt = 7 pt | Rookie Stripez | 1 pt + 2 pt + 2 pt + 0 pt = 5 pt | Rookie jsskppnn | 0 pt + 1 pt + 1 pt + 1 pt = 3 pt | Rookie Congrats Poul!! Edited - Thanks Spiko for bringing my attention to Khekx being clubman when he finished 3rd and should be Pro. Sorry Raheel!
Post by Bandit (PC/PS3/4) on Mar 1, 2010 1:34:53 GMT
Wheee looky me being man in the middle I bet Monstár and Fishy'll downgrade me next month though .. Gotta kick Stripez's arse for not earning an extra point this race Bandit
Post by VGSpeedPro on Mar 1, 2010 14:17:53 GMT
Aaron & Poul did you try ABS On? I am asking this because when I was doing these tracks, I was clearly faster with it... But it can be a matter of Setup...
Congrats everyone! =) I am sorry I didnt participate, but it was for good reason! ;P
Post by aarog5606 on Mar 1, 2010 14:44:08 GMT
I did not use ABS on, which might have helped a little. My problem is with Zonda is with the bouncing. If i went as fast in a few corners as in the videos some of you posted, i would bounce right off the track. I tried everything, lower and higher tire pressures, soften and stiffen springs and shocks, different race lines and nothing helped.
Post by TheGreenMonster (PC) on Mar 1, 2010 15:47:09 GMT
I did not use ABS on, which might have helped a little. My problem is with Zonda is with the bouncing. If i went as fast in a few corners as in the videos some of you posted, i would bounce right off the track. I tried everything, lower and higher tire pressures, soften and stiffen springs and shocks, different race lines and nothing helped. I have the same problem with the Zonda,,, and I'm not even using your setup....
Post by Grnkjr0 on Mar 1, 2010 16:48:53 GMT
Hey Rogerio
No I did not try with ABS on, I am unable to brake late like with ABS off.
I had to run this Karussell track like 500 times to get that 2.01.810. The reason being i could not find the same in game settings and profiler settings like I used when I first practiced this track. I remembered I used something similar to those toe and camber settings like I posted in the Inner Circle thread. I have not tried Norman´s tuning but I doubt I can use it because we use so different settings in game and in profiler. People are asking all the time for tuning setups, but it really depends on your sensitivity settings.
I see that Norman did the 1st sector in his Karussell run from wrecord in 44.562 and when I look at the video of my run I think we are about the same or perhaps I am a little faster, but that 1/2 sec I lose compared to his run I think I lose in that last terrible slow last turn, where you need to slow down into 2nd and then accelerate again. But Norman´s time would probably take me another 500 runs and Karussell is a terrible annoying track, where it is so easy to spin off and just one pull to hard on the wheel and you lose too much time.
Post by VGSpeedPro on Mar 1, 2010 17:51:02 GMT
Hi Poul!
In Nurburgring its not about braking late, its about carrying corner speed, and that is why I was faster with ABS On. You actually dont really brake earlier when corners are most medium speed like its the case here, but because the wheels dont "stop", you can carry more speed on entry, middle and exit, which is fundamental on this kind of tracks. But like I said, maybe setup can overcome it... I will try when I can to do Nuburgring Tracks again and will let you guys know my conclusions! ;P Maybe with the 5850 I can record videos while driving! I will test.
