Post by Jussi on Sept 29, 2014 1:26:12 GMT
Track: Beacon & Station Allowed cars: Currently available Group a cars (5 skill mods required) Restricted cars: Juggernaut editions not allowedPerformance tuning: No parts or 0% durability Mode: Singleplayer only, Multiplayer and Private match are not allowed Power Ups: None (shield and ready allowed on tracks with traffic). One shot of NOS allowed under special conditions explained HERE!Screen 1: Performance shop showing the installed upgrades and performance values of the car Screen 2: Skill workshop screen showing the 5 skill mods installed on the car Screen 3: Unaltered full size after race screen. Wait for 20 seconds before taking the screen or for the first AI driver to finish Written confirmation: Total time - Driver - Car - Overall - Level (Please USE THE SAME NAME IN ALL CONFIRMATION LINES, even if you use different drivers) The 6th digit: Please update your nfstimes.com page before posting your entry and add the missing last digit to your race time. Notice that SpeedAPI only holds the fastest time per track each day, so never use unallowed cars or powerups before you have updated your competition times. If your page does not pick up your time, explain in your entry why you think this happened. Additional confirmation: All entries have to be recorded at the reference board HERE! (You need to register your drivers for the leaderboard here.) Another board at nfstimes.comLeaderboard confirmation: In case reference board fails, link to personal leader board at nfstimes.com must be posted below the confirmation line. Unranked times will not be accepted. If you have times that are marked "under the limit", you need to consult the leaderboard staff about it. ISRC 2 membership (optional) : Register for the leaderboards at nfsunlimited.net and join ISRC Leaderboard. Then you can also add www.nfsunlimited.net/leaderboards/team/ISRC below your confirmation line. Deadline: October 6, 2014, Midnight GMT Prizes: N/A or TBA. Note: These rules are subject to change with or without prior notification.Here's an example of the screens you need. They have to be readable size. Please use full size screens with the tags provided below this example. Also do not forget the written confirmation! 1:38.931 - jsskppnn - Alfa Romeo 8C Competizione - 685 - 60 nfstimes.com/nfsw/pc/JUSSI/times www.nfsunlimited.net/leaderboards/team/ISRC Jussi _______________________________________________________________________________________Drivers here!
Post by dejanboskov on Sept 29, 2014 8:35:58 GMT
So... Boss 302 '12,GT2 or ZR1. On my main driver I got Alfa Romeo 8c and Lotus Evora. I'll try those 2 now and I'll post here.
Post by LamboGTR on Sept 29, 2014 9:09:08 GMT
This post is for DQ line reference.
DQ Line 1:39.712 (Thread) DQ Line 1:38.432 (Leaderboard)
Legend Thread: Time has been proven by being posted on the thread. Leaderboard: Time has been posted on leaderboard but has no post on the thread.
Note: Both times will be the same if time is posted on both.
Post by dejanboskov on Sept 29, 2014 9:31:05 GMT
I'll try try alfa later. The evora slides too much and it's no good against jumps. Here's my entry: 01:40.112 - dejanboskov - Lotus Evora(0% durability) - 655 - 60 nfstimes.com/nfsw/pc/APKAH123/timesedit: since for A class are 3 cars(GT3 RS,LFA and M1 Pro Car)I can only assume that one of them will be in this igc rotation right? Or the LP670 but I think that we'll see one of those I mentioned above re-edit: I just tried the Alfa and from that I can say that the Evora is better than the Alfa I made few runs and I verified that. Here is my best run with the Alfa Romeo 8C 01:41.095 It has better handling than the elise but the nos at the start isn't stronger than the evora's and 8C makes the jumps much better but still doesn't perform much better. I'll try the r35 spec v need to check in which account I had it but it's entered the competition on that I'm sure. I'll make some runs with it and to bad my ex main acc is banned 'cause I had the gt2 on it. re re-edit: 01:41.996 My very first run with this car. I didn't hit the perfect start and I hit the wall couple of times so this is the best car for me then. I'll make more runs with it 'till I make the best
Post by PRAS26 on Sept 29, 2014 14:07:00 GMT
GPU
Post by GPU on Sept 29, 2014 17:14:33 GMT
Tried running a few runs with the GT2, got 1:33 (1:32.99 to be exact). I'm sure someone with a controller can get 1:29 easily. I expected the Zilla to be faster thanks to its monstrous acceleration. Although this may be just bad driving. Also I didn't have full PS. Someone mentioned that the forthcoming IGC rotation could bring LFA or GT3, so I've had a try at those two as well: LFA - It could do ok, but it slides a bit. I used a shot of NOS to counter the non-existent PS (see skill setup) GT3: Amazing. I've just done one single run with it and it actually got a better time than everything else so far. If this comes in the rotation, it's definitely a serious contender.
Post by aheadau on Sept 29, 2014 23:05:07 GMT
Post by ELRIO77 on Sept 30, 2014 0:43:53 GMT
Someone mentioned that the forthcoming IGC rotation could bring LFA or GT3, so I've had a try at those two as well: LFA - It could do ok, but it slides a bit. I used a shot of NOS to counter the non-existent PS (see skill setup) GT3: Amazing. I've just done one single run with it and it actually got a better time than everything else so far. If this comes in the rotation, it's definitely a serious contender. Both LFA and GT3 RS can't be used this race. This is 'group a' and those fall into 'class A'. Anything that starts stock above 700 is in a different grouping. For this week, the A class cars that fall under 700 when stock are allowed.
Post by PRAS26 on Sept 30, 2014 4:00:02 GMT
Post by dejanboskov on Sept 30, 2014 18:52:12 GMT
off-topic:I saw nfs pro street on sale in origin. Now my question is: What would I get in nfs world if I buy nfs pro street and if there is a way to activate those pro street vinyls if I buy the nfs pro street? Thanks.
Post by aheadau on Oct 1, 2014 4:36:00 GMT
off-topic:I saw nfs pro street on sale in origin. Now my question is: What would I get in nfs world if I buy nfs pro street and if there is a way to activate those pro street vinyls if I buy the nfs pro street? Thanks. You dont get anything from Pro Street. Only from shift 2 and Hot Pursuit. The Pro Street vinyls in world are from top-up only. There is currently no way to get them.
tencha
Pura Vida. Costa Rica. UTD member
Post by tencha on Oct 1, 2014 5:11:41 GMT
I did 1:34 with my tuned 8C and 1:32 with tuned R8 I guess i will try GT2 and hope to get 1:32
Post by dejanboskov on Oct 1, 2014 12:07:58 GMT
Well it turns out that the Evora is better than the GTR R35 SpecV but it slides too much so I guess that GT2 996 will do better than Elise since I don't have that GT2 I'll go with the Elise and hope to improve the time by 2 seconds max. 01:37.639 - dejanboskov - Lotus Evora (0% durability) - 655 - 60 nfstimes.com/nfsw/pc/APKAH123/timesI suggest to try the evora too 'cause I want to know which one goes better here. From those cars that I have I'm going for the Evora
Post by Beekilla on Oct 1, 2014 12:44:18 GMT
That is an Evora, not an Elise.
I got 1:36ish time with 8C, but will also try the R35.
Post by dejanboskov on Oct 1, 2014 17:22:22 GMT
That is an Evora, not an Elise. I got 1:36ish time with 8C, but will also try the R35. Ooopsy Fixed Thanks
