Post by Radeg10 on Jan 5, 2014 12:05:15 GMT
shut up nooob and asrnwer about your acceleration Cool down little boy. I can try to explain you. But you will never understand so everything is useless.
Post by badarse95 on Jan 5, 2014 12:07:34 GMT
shut up nooob and asrnwer about your acceleration Cool down little boy. I can try to explain you. But you will never understand so everything is useless. i will if you can
Post by RacerBest on Jan 5, 2014 12:16:09 GMT
He comes out of the corner on 4th gear, while you are stuck on 5th gear. what about 30 degree corner ? He simply takes the corner wider and smoother than you which saves him more speed after coming out of the corner. Oh, but you still don't understand that they way you take corners also affects your speed after it.
Post by badarse95 on Jan 5, 2014 12:20:04 GMT
what about 30 degree corner ? He simply takes the corner wider and smoother than you which saves him more speed after coming out of the corner. Oh, but you still don't understand that they way you take corners also affects your speed after it. from 30 degree turn i meant how he managed to go from 118 kmph to 158 kmph where as i managed to go from 117 to 147 and from 124 to 155 how ? and i also went from outside to inside
Post by RacerBest on Jan 5, 2014 12:36:39 GMT
Post by Radeg10 on Jan 5, 2014 12:38:42 GMT
His video www.youtube.com/watch?v=deiHnNkrRU4My video www.youtube.com/watch?v=9cZXxACEq2I1.After 30 degree turn where he was at 119 kmph , i was at 125 kmph He entered the shortcut at 158 kmph , i was at 155kmph HOW CAN SOMEONE HAVE THAT MUCH ACCLERATION ? in other words his accleration increased by 39 where as mine increased by 30 , difference of 9 in such a short distance is speedbug nthing else I agree with you, this is little weird if you wrote speeds correct. I failed in this corner and i almost crashed wall. We used little different lines. I think i travelled longer distance from lowest speed to shortcut. As you know i used wheel and this is slowest corner in this race and wheel gives greatest advantage in slow speeds. I prepared car for best possible escape from corner? IDK but it´s only wheel + my driving style. Keep best possible speed in corner is not always fastest way. There are much more factors in racing.2. at 1st gril he was at 157kmph at 2nd gril he was at 186 HOW ? i was at 155 then 183 on 2nd gril What? Where is the difference? 1km/h Seriously?3. LAST U SHAPE TURN HE TOOK AT 189 , i took at 198 how come his went upto 220 at that slight corner and mine went only to 219 We both little failed here. Your line is longer. I used 4th gear, you 5th all the time. Every car has much better acceleration in 4th gear than 5th.4. At strting he didnt even go from inside the pursuit breaker where as to maintain that much speed we need to go from inside the pursuit breaker I was driving inside the breaker all the time. But then i decided skip this because. There is not big advantage i think. Going inside is only more risky. 5. You skipped this: Before 1st straight i had much better cornering speed. Me 215, you 206. This gave me >1s i think. 1st straight is quite long. You failed a lot here.AND WHEEL IS NOT AN EXCUSE BECAUSE M ALSO USING XBOX CONTROLLER Sorry but xbox controller is not wheel. Do you know what is steering wheel? My text is red.
Post by Tomek on Jan 5, 2014 13:05:21 GMT
I'm not that good and experienced enough driver to judge other players like that, but I agree with Chandrian (in case you don't know, he is also moderator here, but I don't know why he don't have visual moderator status) - I don't see any speedbug or speedhack here. But you want to tell us, that you think, that you had perfect racing line and you didn't make any mistakes in your run? And could you be so kind and write in normal language in Shoutbox too? Because I don't want to waste my time, trying to understand what you're saying. I will proove that parts combination is bullshit excuse for his acceleration you people probably dont know me well i guess now you all will SPEEDHACK & SPEEDBUG & ACCELERATION HACK IS TOTALLY THREE DIFFERENT KIND OF HACKS and i am 100% sure its accel hack STAY TUNED YOUR "PART COMBINATION " VIDEO IS COMING SOON Where in my post you see something about parts setup? And you didn't answer to my question. Also you still are using this weird writing style. So that means, that you don't care at all about what I'm saying. You even contradicting yourself: And being a moderator does not mean that a cheater cheat and act like a genuine player You wanted our opinion so you've got it. But I think that you are able to acknowledge only one opinion - consistent with your own. m not saying anything about your time i dont care if its possible or not , I AM JUST TALKING ABOUT your accleration You don't remember, that you started your little crusade under the banner "How's this time is possible" in Shoutbox? And while we are at this investigation mood brought by you, could you care to explain, how you've got this Achievement CCX (between Charger and Cayman)? P.S. Do you know, that you can edit posts, instead of creating one after another?
Post by nevermemos on Jan 5, 2014 13:18:23 GMT
Post by un1que on Jan 5, 2014 13:22:55 GMT
No more pointing fingers kids....
Just play the game.
Post by hasserro on Jan 5, 2014 13:23:15 GMT
nope, if ts gonna be faster cars I will kick your a$$ xDD
Post by Lycain on Jan 5, 2014 13:25:47 GMT
Your Diablo against my Capri wow will be interesting!!! N O O B...
Post by anandvmaster on Jan 5, 2014 13:36:33 GMT
My car reached 0 durability after the race. should i upload 599 rated photo ? or upload 584 rated photo. Below is my entry tired a lot but this was my fastest run without hitting any thing on road. i missed the video. 1:31.420 - ANANDVMASTER - BMW M3 GTR E46 - 599 - 60 nfstimes.com/nfsw/pc/ANANDVMASTER/times
Post by LamboGTR on Jan 5, 2014 13:49:07 GMT
I just find it ironic that a former hack abuser is calling someone else a cheater. Too good. Jussi has banned others for having a history of hacking so forget about this kid.
Post by badarse95 on Jan 5, 2014 13:57:15 GMT
I just find it ironic that a former hack abuser is calling someone else a cheater. Too good. Jussi has banned others for having a history of hacking so forget about this kid. I HAVE ALREADY TALKED TO JUSSI ABOUT IT AND HE KNOWS ABOUT MY OLD ACC SO PLZ
Post by badarse95 on Jan 5, 2014 13:59:38 GMT
His video www.youtube.com/watch?v=deiHnNkrRU4My video www.youtube.com/watch?v=9cZXxACEq2I1.After 30 degree turn where he was at 119 kmph , i was at 125 kmph He entered the shortcut at 158 kmph , i was at 155kmph HOW CAN SOMEONE HAVE THAT MUCH ACCLERATION ? in other words his accleration increased by 39 where as mine increased by 30 , difference of 9 in such a short distance is speedbug nthing else I agree with you, this is little weird if you wrote speeds correct. I failed in this corner and i almost crashed wall. We used little different lines. I think i travelled longer distance from lowest speed to shortcut. As you know i used wheel and this is slowest corner in this race and wheel gives greatest advantage in slow speeds. I prepared car for best possible escape from corner? IDK but it´s only wheel + my driving style. Keep best possible speed in corner is not always fastest way. There are much more factors in racing.2. at 1st gril he was at 157kmph at 2nd gril he was at 186 HOW ? i was at 155 then 183 on 2nd gril What? Where is the difference? 1km/h Seriously?3. LAST U SHAPE TURN HE TOOK AT 189 , i took at 198 how come his went upto 220 at that slight corner and mine went only to 219 We both little failed here. Your line is longer. I used 4th gear, you 5th all the time. Every car has much better acceleration in 4th gear than 5th.4. At strting he didnt even go from inside the pursuit breaker where as to maintain that much speed we need to go from inside the pursuit breaker I was driving inside the breaker all the time. But then i decided skip this because. There is not big advantage i think. Going inside is only more risky. 5. You skipped this: Before 1st straight i had much better cornering speed. Me 215, you 206. This gave me >1s i think. 1st straight is quite long. You failed a lot here.AND WHEEL IS NOT AN EXCUSE BECAUSE M ALSO USING XBOX CONTROLLER Sorry but xbox controller is not wheel. Do you know what is steering wheel? My text is red.OH WELL I GUESS ITS OK THEN , i just wanted you to explain it nothing else tho it looked weird
