s3by
Professional Romanian
Post by s3by on Mar 9, 2013 19:59:10 GMT
I brake for most turns with any car. I simply don't have the guts to trust my racing lines. Jussi Just go for them. You might also find out even better lines
Post by Deleted on Mar 9, 2013 20:40:06 GMT
I used to drive it in B class races, but without success since it doesn't give the best. In A class ultra tuned is a major opponent, the supreme handling did the job on this track, used the brake only one or two times. Ricc I brake for most turns with any car. I simply don't have the guts to trust my racing lines. My biggest mistake on yesterday's track was using too much brakes. I remember someone once saying that they only need to use brakes once for that backwards turn at Dover and Lepus. Jussi When I'm under pressure I often end up using brakes too much. The feeling that I'm going to do an error sometimes kills my timing. On boundary & Marina using M3 Sport Evolution it's quite the same, but the uber handling this car has really makes braking useless. Follow the track path and take corners from the inside, this is the trick. Ric
Post by sinisterknight on Mar 9, 2013 20:51:07 GMT
Post by Deleted on Mar 9, 2013 21:09:33 GMT
you have to resize the piture using the resize tag if you're using 16:9 proportions and write the results in the right way: timing - driver's name - car used - OA - driver's level Ric
swoos
Post by swoos on Mar 9, 2013 22:16:58 GMT
nvm
Post by yuufaisallout on Mar 10, 2013 5:15:53 GMT
danish
Banned for cheating
Post by danish on Mar 10, 2013 5:42:28 GMT
Post by sparco23 on Mar 10, 2013 14:38:27 GMT
Post by whiskeyandcola on Mar 10, 2013 15:37:59 GMT
Post by FasterthaMyou on Mar 11, 2013 13:46:35 GMT
Post by pumpedupkid on Mar 13, 2013 11:23:02 GMT
Post by kashifkim on Mar 14, 2013 13:57:06 GMT
Gigaxero
Its all about the driver
Post by Gigaxero on Mar 14, 2013 15:12:35 GMT
Post by Jussi on Mar 14, 2013 16:47:22 GMT
New troll-king. Take GT2's stock performance, add Exige's handling and you get this I want one or few of those (for different classes). Jussi
Post by RacerBest on Mar 14, 2013 17:32:31 GMT
