Post by corairs on Oct 7, 2009 19:17:15 GMT
Hey Tom Have you tried to install the Shift patch yet? It is needed for online play and otherwise you will have to wait and see if there will be a new patch out to deal with all the problems people are having. Poul I heve the patch installed it play'a ok online no lag it's only in career is whin it lag's .
Post by RicardoElfrinko (PC) on Oct 7, 2009 19:18:30 GMT
Spiko asked me to be his friend and I replied. Later on he was gone on the list. For me the only one who survives is Jussi.
Post by Jussi on Oct 7, 2009 19:40:54 GMT
I had some nameless character, Khekz and Corairs on my list today, but now only Corairs. This is totally screwed!!! Jussi
Post by Jussi on Oct 19, 2009 19:48:48 GMT
What do you call this bug... I was online and my Viper refused to move! Jussi
Post by Grnkjr0 on Oct 19, 2009 19:50:48 GMT
The same thing happend to me today trying to test a Viper on Autopolis Lakeside. I tried to set default in advanced tuning but nothing helped. It just would not move....
Post by jeffareid on Oct 19, 2009 19:54:33 GMT
This bug is related to the last tuning method used, regardless of the car. Buy a "spare" car for the work around. Select that "spare" car, go into tuning menu, select quick tuning and make some change, like steering 49%. Once this is done, run a race in the Viper again, and do a restart to make sure the fix works. Then save your game.
Post by Jussi on Oct 19, 2009 20:13:14 GMT
That Viper was actually a stock car or a loaner... I changed the game settings and that car just appeared there for me, then everyone pressed "2" before I could choose my own car. Jussi
Post by corairs on Oct 20, 2009 2:44:16 GMT
I'm had the same thing happen to my car man .
Post by jeffareid on Oct 20, 2009 2:52:35 GMT
This bug is related to the last tuning method used, regardless of the car. That Viper was actually a stock car or a loaner... Doesn't matter if it's a stock car, loaner car, or careeer car. What matters is the last tuning method you used on any car, quick or advanced. If you used advanced, then certain muscle cars won't move. If the last tuning method used was quick, regardless of which car you tuned, it will fix the problem on all of the problem cars, but you may have to restart a race. You'd have to do the restart in an offline race first, then save that game and use it for online racing. Note that the advance tuning you've done on other cars isn't affected by the quick tuning you do to another car to workaround this problem.
Post by Jussi on Oct 20, 2009 5:33:43 GMT
What matters is the last tuning method you used on any car, quick or advanced. OK, now I understand! Thank you very much, Jeff. Jussi
Post by DJ (PC/360) on Oct 23, 2009 1:34:54 GMT
I'm having problems starting a race. After I get the settings in (track then car,) it will crash. I don't have the first patch installed but I got the Wipe Out Mod installed and running on Vista.
Post by rcgldr on Oct 23, 2009 2:22:55 GMT
I've done more testing, and sometimes the quick tuning doesn't fix the problem with the Viper. I wouldn't trust the car online, because I'm seeing my setups change from race to race on some cars.
Post by Jussi on Oct 23, 2009 5:26:57 GMT
I'm having problems starting a race. After I get the settings in (track then car,) it will crash. I don't have the first patch installed but I got the Wipe Out Mod installed and running on Vista. Go to C:\Users\DJ\Documents\NFS SHIFT in other words "My Documents\NFS SHIFT" and open graphicsconfig.xml in notepad... Then replace these lines... <prop name="Name" data="" /> <prop name="Mode" adapter="0" width="800" height="600" antialias="0" refresh="60" /> <prop name="Vsync" vsync="0" /> <prop name="Windowed" windowed="0" /> <prop name="TextureFilter" texturefilter="0" /> <prop name="TextureResolution" textureresolution="0" /> <prop name="Brightness" brightness="10" /> <prop name="CarDetailLevel" cardetaillevel="0" /> <prop name="TrackDetailLevel" trackdetaillevel="0" /> <prop name="ShadowDetailLevel" shadowdetaillevel="1" /> <prop name="MotionblurLevel" motionblurLevel="0" /> <prop name="EffectsDetailLevel" effectsdetaillevel="2" /> ...or fill in the values from that code. If you can do a race with those settings, then change the graphics in the game, but only one setting at the time, so you'll see which one it is that stops the game from running correctly. Jussi
Post by Bandit (PC/PS3/4) on Oct 23, 2009 17:07:49 GMT
The only real technical issues i have is a lousy framerate on some tracks and some parts of tracks i have not really 'investigated' further .. I know that Tokyo track thingy got some issues and lets face it: my Radeon HD4870 512MB DX10 shouldn't be the problem here, i think ... ? Bandit
Post by Grnkjr0 on Oct 23, 2009 17:16:02 GMT
