Post by Hornet on Aug 23, 2010 11:28:23 GMT
Hi ppl, I need advice and tuning setups for stage 3 Lamborgini Gallardo that will enable me to reach Road America 1:56:xx lap time. I use only ABS assist (stability and traction off) and with no mistakes my best time, with G27 wheel, is about 1:59. If somebody made 1:56 lap time please post me a setup.
Post by TheGreenMonster (PC) on Aug 23, 2010 11:51:58 GMT
Welcome Nevenmraz.. I just sent you an email, go and read it and follow the directions Hi ppl, I need advice and tuning setups for stage 3 Lamborgini Gallardo that will enable me to reach Road America 1:56:xx lap time. I use only ABS assist (stability and traction off) and with no mistakes my best time, with G27 wheel, is about 1:59. If somebody made 1:56 lap time please post me a setup.
Post by Hornet on Aug 23, 2010 15:15:17 GMT
Thanks for the wellcome Green, I think I'll join PBRC, but considering tuning I still need some good setups for GaLLARDO from pro racers. If you have any please post me. I already tried setups from www.nfsunlimited.net and www.gtplanet.net and my best is still 3s away on Road America.
Post by TheGreenMonster (PC) on Aug 23, 2010 15:36:10 GMT
I can't really give you any tuning information till you complete the 4 weeks of the PBRC races. I can tell you this lose the Gallardo and use a LP640 or a Zonda for a better time with Road America.. Check out our crew on wrecord stats wrecord.com/stats_team.phpThanks for the wellcome Green, I think I'll join PBRC, but considering tuning I still need some good setups for GaLLARDO from pro racers. If you have any please post me. I already tried setups from www.nfsunlimited.net and www.gtplanet.net and my best is still 3s away on Road America.
Post by SPEEDFr3ak on Aug 23, 2010 15:37:57 GMT
Thanks for the wellcome Green, I think I'll join PBRC, but considering tuning I still need some good setups for GaLLARDO from pro racers. If you have any please post me. I already tried setups from www.nfsunlimited.net and www.gtplanet.net and my best is still 3s away on Road America. you need to train the track then
Post by VGSpeedPro on Aug 24, 2010 11:18:37 GMT
Join us and you will have access to one or two setups that allow the LP560 to do 1m 56s in Road America with just Rating 14.00! ;P
Also, by Racing in our PBRC's, you will increase your level as a Driver. Dont think that the only reason why you cant do those times is because of a Setup...
Post by Grnkjr0 on Aug 24, 2010 11:32:11 GMT
Post by Paragleiber on Aug 24, 2010 21:53:18 GMT
I can't really give you any tuning information till you complete the 4 weeks of the PBRC races. Why is that? Do you think he's a cheater? I think you should be a bit more welcoming to new people and not suspect everyone is bad until he proves that he is not...
Post by VGSpeedPro on Aug 24, 2010 22:06:24 GMT
The problem is not that... That is there to make sure that people just dont come here to take the setups and then disappear without making any kind of contribution! ;P
Post by Hornet on Aug 25, 2010 9:14:55 GMT
I'll join for sure ppl, been driving Silverstone GP all day yesterday. And BTW I understand why you don't just give setups away.
Post by rcgldr on Aug 25, 2010 10:02:58 GMT
The setup info in this zip file is what I use online, and can be given away, as either it's stuff I figured out myself or stuff I got from others that stated it was OK to share. There's also a test savefile: rcgldr.net/nfss/nfss.zip
Post by TheGreenMonster (PC) on Aug 25, 2010 20:06:40 GMT
You could try to use rcgldr setup information however he drives with joysticks and not a steering wheel or even a gamepad. www.logitech.com/en-us/gaming/joysticks/devices/5855However Joining ISRC, PBRC races you will get access to wheel support setups, tuning help for class 4.0,- 6.0, -10.0 -14.0 and unrestricted cars from some of the fastest racers and best tuners on this planet like. VGSpeedPro. Grnkjr0, Cipraini , Aarog5606, rtxus, Dreamgate,SpeedFre3k, LightingBullet, We all use these tuners setup information and with a few slight changes you'll be able to compete with them. check out the top ten racers on wrecord.com wrecord.com/-------------------------------------------------------------------------- The setup info in this zip file is what I use online, and can be given away, as either it's stuff I figured out myself or stuff I got from others that stated it was OK to share. There's also a test savefile: rcgldr.net/nfss/nfss.zip
Post by Grnkjr0 on Aug 25, 2010 20:27:19 GMT
Hey all I guess 4 weeks is a little long to wait, so I decided to share my tuning, which is the one I use for online racing. People need to adjust the tuning to their driving style, but the most important thing in this setup is the parts used - (think it was Spiko who discovered this combination - can´t remember). Have fun and go kick some butt. Edited: No, the combination of parts to be used was discovered by xXxH0TRIDExXx Poul Gallardo LP560-4 The parts used: Drive/engine/turbo/tires Stage 3 Weight Stage 3 Seam-welded chassis Tuning: Fr. pressure - 31.45 Rr. tire pressure - 33.48 Brake bal. - 61.50 - Steering lock - 30.00 Caster - 1.50 Fr. toe - -0.50 Rr. toe - -0.80 Fr. camber - -0.90 Rr. camber- -1.00 Fr. ride height - 75.00 Rr. ride height - 85.00 - Fr. sway bar - 57.10 Rr. sway bar - 57.10 Fr. spring rate - 399.73 Rr. spring rate - 485.38 Fr. bump stop length - 0 Rr. bump stop length - 0 Fr. damper slow bump - 3,800 Rr. damper slow bump - 3,200 Fr. damper fast bump - 2,200 Rr. damper fast bump - 2,000 Fr. damper slow rebound - 12,100 Rr. damper slow rebound - 11,000 Fr. damper fast rebound - 8,600 Rr. damper fast rebound - 8,000 - Limited slip preload - 60.00 Visco ele. lock - 30.00 - Final - 6.20 1 - 3.23 2 - 2.54 3 - 1.80 4 - 1.39 5 - 1.17 6 - 0.97 - Fr. downforce - 18.00 Rr. downforce - 18.00
Post by Hornet on Aug 25, 2010 20:45:04 GMT
Thanks for the encourigement Green and for the setups Grnkjr0 and rcgldr. I allready tried rcgldr's(you ppl sure have memorable names LOL) and it is for joystick all right. I was flying all over the track. Its all about what you r used to drive with I guess. Anyway I changed my name to something more sutable. Thanks again for the inicial help.
Post by rcgldr on Aug 25, 2010 22:03:01 GMT
I did some testing and stage 3 tires seemed faster or at least the same, so since most other players using stage 3 tires I changed LP540 setup in my guide (and the savegame). Link is the same. rcgldr.net/nfss/nfss.zip
