Post by gregmoore on Aug 9, 2010 18:21:06 GMT
so how can my sons and I all submit our own and separate WR attempts.. using 1 PC and 1 WRClient?
... and now over to TheGreenMonster in the news room...
thanks GM
Post by TheGreenMonster (PC) on Aug 9, 2010 18:28:41 GMT
This to easy but here goes. Since wrclient isn't install on the HD it just sits on the HD in a folder what you need to do is; 1. The first wrclient rename the ICON to Greg 2. download a new copy of wrclient to the HD into a separt folder 3. unpack it and rename the second copy ICON to your son name the folder are separted and when greg runs wrclient you use your icon when you're son play the game he runs his ICON two different ICON two diffeent log files. so how can my sons and I all submit our own and separate WR attempts.. using 1 PC and 1 WRClient? ... and now over to TheGreenMonster in the news room... thanks GM
Post by gregmoore on Aug 9, 2010 18:36:38 GMT
ok cool ty GM
my boyZ will be pleased
weeeeeeeeee!
Post by TheGreenMonster (PC) on Aug 9, 2010 19:21:15 GMT
If that doesn't work I have one more solution for you that will work guarantee...
Post by gregmoore on Aug 10, 2010 4:01:56 GMT
nope that didnt work....
what else can i try?
Post by TheGreenMonster (PC) on Aug 10, 2010 10:19:37 GMT
I should have said this the first time; I hope I can explain this right When I said my son and I have two different profiles, we have two different game files too; you need to start a second career when the game boots up select start new career...Name that new career Profile name one of the other EA Alias that you're son uses That way there are two completely different game files Inside my shift folder inside My Documents the first folder is my profile name, The second one is my son profile nameā¦ see the example below. Now you can take you're game file and copy it to your son's folder and then rename that game file to the name he select. before doing that delete the one that is already in there, because you can't have two files with the same name in the same folder. My game file is the TheGreenMonster and his game file is name TheDarKnight.....This should work,, Try that first and then let me know. there is also one more variable that might cause problems but try this first and let me know nope that didnt work.... what else can i try?
Post by TomasT (PC) on Aug 10, 2010 10:49:34 GMT
I'm not sure how this works. But I know that I didnt have any problems when I used different save files with the same wrecord-account. I have my old that is TomasT, and the new one called Lightning. Both of those are copys of Rcgldr's public save file, and different from my first save that crashed, that I used when I first registered at wrecord.
Shouldnt it only be controlled by the actual login info in wrecord client?
Post by TheGreenMonster (PC) on Aug 10, 2010 11:05:05 GMT
Oh yes I didn't think of that, Greg you're son needs to register for his own account at wrecord and his ICON should have his user name and password on it and not you're... That most likely the problem here you might not have to create a new game file. He would also need his own email address not to complicate matters. Good job Tomas I'm not sure how this works. But I know that I didnt have any problems when I used different save files with the same wrecord-account. I have my old that is TomasT, and the new one called Lightning. Both of those are copys of Rcgldr's public save file, and different from my first save that crashed, that I used when I first registered at wrecord. Shouldnt it only be controlled by the actual login info in wrecord client?
