Post by TheGreenMonster (PC) on May 2, 2010 20:36:23 GMT
I should have thought of this before the last day of racing... Who can take out the most cop cars..... Maybe by the next beta if there is still another one..... 55 cop cars 27.25.87 150.010 rep points
Post by spiko on May 2, 2010 21:14:02 GMT
from lvl 10 to lvl 15 after this one:)   I did this run couple hrs ago since the multi player racing don't load for me today. Spiko
Post by TheGreenMonster (PC) on May 3, 2010 2:34:44 GMT
Good job Spiko, dang you got 100,000 more rep points for only 14 more cars, I tried to beat your score today but seem the cars wont shift into 6th gear... I'm stuck at 160 Mph
NFSDrew said the problem started mid day Sunday,,,, no one had there 6th gear.... So you da man...this time....
Post by rcgldr on May 3, 2010 2:44:46 GMT
That bug happens when you add "need for speed" skill (increases top speed). 1/3 is marginal, but 2/3 and 3/3 get stuck in 5th, unless you keep tapping "shift" key while going downhill (and maybe if using nitrous). With 1/2 BMW went 200 mph, with 2/3 it went 211 mph during a pursuit, got a reckless driving. It wasn't good for racing, because even with tapping "shift" key it takes several seconds before it finally shifts. I reported this at ea forums earlier today, and also a bug report. > 1.48gb Turns out that's the "uncompressed" size. The download was about 550MB, same as before, no new areas, except for the discovery of the "showcase" city that's off the main map.
Post by RGX (Xbox (360)/Wii/PC) on May 3, 2010 2:58:03 GMT
And where is that?
dkasper0
Post by dkasper0 on May 3, 2010 4:08:02 GMT
Great session, I made it all the way to lvl 13 this time.
Post by rcgldr on May 3, 2010 4:15:56 GMT
No new areas, except for the discovery of the showcase city that's off the main map.
dkasper0
Post by dkasper0 on May 3, 2010 4:21:30 GMT
Post by MadMustang (Xbox, Wii,PC) on May 3, 2010 9:54:51 GMT
Ok guys, seeing nobody seems to be complaining ill do the next beta test  Madster
Post by rcgldr on May 3, 2010 11:22:29 GMT
I took a pair of videos, showing leveling up the hard way by racing the Nissan Silvia until I had enough cash to buy the BMW. The BMW videos is the last run I had with it before the "need for speed" 2/3 upgrade I applied at level 20 glitched the car. You can see the wire mesh crash effect in the videos. The cars are also faster than previous betas: rcgldr.net/nfsw/nwb4lvlup.wmv
Post by Jussi on May 3, 2010 16:47:33 GMT
Once again, the test ended too soon. I mean I could've played few more days even with that low FPS. Here's my best pursuit...  It's not as long as the other guys', but I started to get scared so I had to get away.  Jussi
Post by rcgldr on May 3, 2010 20:30:53 GMT
The scariest part of a long pursuit mode was knowing the game could crash while you were 20 to 30 minutes into a pursuit. The instant cooldown power up compensates for the game spawning cops and/or road blocks everywhere while you're in cool down mode if at heat level 5. The stadium cooldown spot often doesn't work because the game spawns a road block too close to that spot.
Post by makakycs (PC) on May 4, 2010 11:13:35 GMT
I think this is the best I did (too many screenshots to sort through) I got an idea that this was also my first pursuit and the only one that didnt crash when I got over 10 minutes  PS: went from level 5 to 11
