Post by Jussi on Nov 21, 2009 20:59:41 GMT
Post by Jussi on Nov 24, 2009 17:04:09 GMT
Did anyone else try this yet? Jussi
Post by koop777 on Nov 25, 2009 7:56:30 GMT
Yes, I did yesterday but it doesn't use the account I want.....If I put in MYNFS-link it uses HF_bladezzz which is a "extra" profile. I couldn't get it to work....
Post by Deleted on Nov 25, 2009 10:23:01 GMT
koop, you don't need to enter your MyNFS id, you can just type in the PSN account you want to use and it should use that one. Go here: www.nfsunlimited.net/?p=sr_ea_persona and enter the PSN name you want to use in the "Gamertag / PSN Id / PC Username:" box, click the Find button and you should be good to go with the right PSN account If you're still having trouble after this, let me know and I'll get it changed in the database for you. Cheers, GT 8)
Post by koop777 on Nov 25, 2009 12:13:08 GMT
I've tried that, "it" couldn't find me so I went for option#2.....And everthing looks fine If I click on SHIFT it "picks" HF_bladezzz and has a "normal" i-net-adress above. From there you can pick a different persona and the above link changes to this: http: //www.needforspeed.com/web/nfs/mynfs/shift/player?p_p_id=nfspersona_WAR_nfscportlets&p_p_lifecycle=1&p_p_state=normal&p_p_mode=view&p_p_col_id=column-1&p_p_col_pos=1&p_p_col_count=3&_nfspersona_WAR_nfscportlets_action=persona. update
Post by Deleted on Nov 25, 2009 12:24:57 GMT
Right ok, maybe the tool has a problem with people who run multiple personas. I'll see if I can get Bojan (the admin) to fix it for you.
Post by koop777 on Nov 25, 2009 12:36:03 GMT
Right ok, maybe the tool has a problem with people who run multiple personas. I'll see if I can get Bojan (the admin) to fix it for you. That would be great..! Bladezzz was only used in the time HF_koop didn't upload times HF_koop777 will be the only one used online from now on
Post by Deleted on Nov 25, 2009 12:49:02 GMT
Yep, got hold of Bojan and he's gonna fix it for you when he gets home from work. He's GMT+1
Post by Deleted on Nov 27, 2009 21:47:20 GMT
Ok, Bojan has changed the PSN/nick/Gamertag search code and it should now work better for people with multiple personas. Can you try the form again koop? The top box should do the trick.
