Post by paul on Nov 17, 2009 23:17:33 GMT
Hi ! Interesting story, Poul ! We all know those type of peoples, its unhappy but it is. This is why I do not racing online with unknown people, I affread of this. I am curious for this vid, not only because the aggresive rivality, but the speed bug... EA will really resolved some bugs, I can trying get mid 47" whole day and some other do it in first online race About my time, small improvement is possible, I did (good) 1st lap in 51.200, (good) 2nd in 47.913, but small mistake in 3rd, 48.400. I am using same parts as Skroting, setup soon in Inner circle 2.27.530 - paul - Nissan GTR35 Spec-V - 14.00 Cya ! Paul
Post by Grnkjr0 on Nov 18, 2009 3:26:00 GMT
Here is that video of my online play, setting what is likely the fastest lap time time ever with GT-R SpecV on Glendale West. It ranks as 4th on leaderboard, right up there with the Zonda times. Poul www.youtube.com/watch?v=W1aKfJu2duc
Post by bobbyvey on Nov 19, 2009 19:50:59 GMT
Aaalrighty then.... here's my current time for this race, not bad, could be a bit better though, might be updated till Sunday... 2:27.510 - BobbyVey - Nissan GT-R SpecV 14.00 - video added www.youtube.com/watch?v=cduJzs7p9g8@pro mates: which are my weak spots in driving? Pls I need some feedback in order to improve myself...thanx
Post by spiko on Nov 21, 2009 5:21:10 GMT
update 2.27.120-Spiko-GTR35V-14.00 Spiko
Post by Grnkjr0 on Nov 21, 2009 7:04:27 GMT
Bobby can you upload a video of the actual race? That is so much better if you need advice on where you are losing time compared to my time. It is hard to tell from a replay, but my guess is you are sliding too much and not holding best speed possible. I will upload a video of this race later today - hopefully an improvement of my current best time.
I also suggest you try Rogerio´s SpecV setup from Inner Circle and perhaps set the tire pressure somewhat higher, with most on the front. I forgot do you use the G25 wheel?
Post by bobbyvey on Nov 21, 2009 9:30:36 GMT
Unfortunately, while recording, my fps won't go over 30 and I'm afraid it's not enough for making really fast times. That's why I post only replays. Yes, I use G25, set rotation to 360°. Rogerio's set up has been applied long ago, and it's quite the best, I could try a bit higher tire pressure though, but I guess it would slide even worse then... I generally play with gear ratios to see which suits best to each track. thanks for ur time!
Post by Grnkjr0 on Nov 21, 2009 10:05:04 GMT
Bobby.. I use much higher tire pressure and I have no grip problem at all. I stay in 4th and only use 5th going towards the racing line. I have set 4th gear to max top speed. My G25 settings are: all sensitivity on 50% on steering wheel, brake, clutch and accelerator. My settings in Profiler are all set to 150%, except overall strength effect on 132%. I use 201 degrees of rotation. Try all these settings and the ones in the picture and I think you will make an improvement on this track. Poul
Post by Grnkjr0 on Nov 21, 2009 10:08:03 GMT
I can take that 1st corner on 1st lap going 149 km/h, so you won´t have a grip problem with these settings.
poul
Post by bobbyvey on Nov 21, 2009 11:05:21 GMT
hmmm, those are really different in game control settings, as well as profiler ones. here's mine: I will definitely try urs and see what happens. Thanx again! btw I forgot to post a little update... 2:27.280 - BobbyVey - Nissan GT-R SpecV - 14.00
Post by Grnkjr0 on Nov 21, 2009 11:52:36 GMT
Well I do not know what settings are the best in this game. At least these are working for me. I think perhaps the game has a input lag or delay when steering is applied and to the actual turn. I have tried a lot of different G25 and in game settings and these are the ones I like the most.
You do not want any deadzone values above 0 and usually 50% sensitivity is the best for a racing wheel, but with all the bugs in this game you never know what might suits you the best.
Post by Grnkjr0 on Nov 21, 2009 12:33:37 GMT
Here is an update: I will upload the video of this run for Bobby and hopefully you will be able to improve your time. In this I used 44 on downforce and steering lock set to 31 and acceleration to 6.04 - just one tap to the left from middle - forgot what that value was. My lap times were not that great. 1st was 50.155 or something and 2nd 46.964 - nothing to write home about. But the last lap was an impressive 46.666, now I only need to make 3 perfect laps before this one closes tomorrow. I will upload that video now. Poul 2.23.770 - Grnkjr0 - Nissan GT-R - SpecV - 14.00
Post by aarog5606 on Nov 21, 2009 12:40:10 GMT
Will definetly shave a second off this time when i get the chance. 2:24.960 - aarog5606 - GTR SpecV - 14.0
Post by Grnkjr0 on Nov 21, 2009 13:51:49 GMT
Here is that video. Notice how I brake and downshift to 3rd trying to keep the car close to the right side on that downhill curve. I also lift the gas pedal in 2nd lap after the finish line, going into the big turn and then accelerate again with only half throttle or so until I am sure I have grip. Poul www.youtube.com/watch?v=kQgbv7ANmuQ
Post by bobbyvey on Nov 21, 2009 16:20:16 GMT
I guess some of ur advices actually helped me, or I was just lucky, managed to save one second. I couldn't put my 4th gear all the way right to 'speed' due some obvious bug (it keeps resetting itself back) so I think I would have gone a bit faster but hey, I'm sort of pleased with this..... 2:26.540 - BobbyVey - Nissan GT-R SpecV - 14.00
Post by Grnkjr0 on Nov 21, 2009 16:29:56 GMT
Well one second Bobby in these PBRC´s is actually a lot. I remember with Undercover, that Rogerio, Khekz, Aaron, Spiko and myself was within 1 second in one event.
Did you try the sensitivity settings on Logitech profiler and the in game settings I posted? It is most likely there you gain those seconds you are missing. I know it is a lot to change all that, but hey if it will make you faster its worth it. Just write down your old settings and you can try mine in 5 mins.
Edited: My 4th gear also resets itself after tuning.
