Post by CmdrTomalak (PC/PS3/PS4) on Aug 15, 2019 17:30:45 GMT
Not sure if anyone has ever used the Widescreen fix for this game but if you have, I'm curious if anyone has been able to get it to work properly with Windows 10? I got it from here: github.com/ThirteenAG/WidescreenFixesPack/releases/tag/nfsmwbut when I try to run the game after putting the files in the game directory, my game won't run. If I remove the files from the game directory, the game runs. Anyone? Couldn't think of anyone else to ask seeing as the game is kinda' old.
Post by Bandit (PC/PS3/4) on Nov 27, 2019 13:36:37 GMT
I'm playing it again the last couple of days and i have the widescreen fix working even on my ultra wide screen. As i remember it, i installed two different versions because i had the same issue; The game wouldn't start with the first one. After installing the second one, i removed the files from the first one and it miraculously worked. I'll see if i can find out what exactly i did to get it working and will update here once i have. --edit-- Try installing this: www.nfscars.net/need-for-speed-most-wanted/7/files/view/5985/--edit-- Cheers!
