Post by Deleted on Dec 19, 2014 13:20:55 GMT
This .dll file isn't part of Windows 7 x64 Professional N SP1. I've searched for it on my PC. You will have to reinstall the driver or if the installer is corrupted on your CD, then try to download the proper driver for your OS from the hardware's manufacturer site (usually it's available). In case you can't find a solution in time, and if you know that you might be able to run the game without this specific driver, then you can uninstall it temporarily.
Post by Radeg10 on Dec 19, 2014 15:36:25 GMT
is Carrera GT allowed?
Post by dejanboskov on Dec 19, 2014 17:10:44 GMT
This .dll file isn't part of Windows 7 x64 Professional N SP1. I've searched for it on my PC. You will have to reinstall the driver or if the installer is corrupted on your CD, then try to download the proper driver for your OS from the hardware's manufacturer site (usually it's available). In case you can't find a solution in time, and if you know that you might be able to run the game without this specific driver, then you can uninstall it temporarily. See the attachment.
Post by Tomek on Dec 19, 2014 19:04:16 GMT
Yes. And I must add it to the cars list.
oscar
Post by oscar on Dec 19, 2014 19:57:42 GMT
This .dll file isn't part of Windows 7 x64 Professional N SP1. I've searched for it on my PC. You will have to reinstall the driver or if the installer is corrupted on your CD, then try to download the proper driver for your OS from the hardware's manufacturer site (usually it's available). In case you can't find a solution in time, and if you know that you might be able to run the game without this specific driver, then you can uninstall it temporarily. See the attachment. I have windows 7 64bits and I have not this file. This is a driver for an external application to windows, see the description of the file (OSBASE WDDM User Mode Driver) of OSBASE company. This is their website. osbase.com/It has several products to download their drivers, look to see what is yours (you should have one of these installed in your case). See if reinstalling the driver is solved Edit. Try to reinstall the graphics card drivers, just in case
Post by dejanboskov on Dec 19, 2014 20:39:45 GMT
I have windows 7 64bits and I have not this file. This is a driver for an external application to windows, see the description of the file (OSBASE WDDM User Mode Driver) of OSBASE company. This is their website. osbase.com/It has several products to download their drivers, look to see what is yours (you should have one of these installed in your case). See if reinstalling the driver is solved Edit. Try to reinstall the graphics card drivers, just in case That was one of the many thing I did(with the VGA drivers). This thing happened right after my brother placed this pci card for usb3.0 and sata 3. The installation went wrong and those drivers weren't installed properly so he reinstalled again but I still have this problem and the thing is that the hdd is wired to this card because it's sata3(which my motherboard don't exactly support it and the hdd worked slowly) so is there going to be a problem if I remove the drivers and install them again? edit: I found this driver but idk if this going to mess up completely if I uninstall that and everything related to it Attachments:
Post by Deleted on Dec 20, 2014 12:40:15 GMT
Post by FasterthaMyou on Dec 20, 2014 21:42:52 GMT
Post by Tomek on Dec 21, 2014 1:21:41 GMT
Post by GustavoAP on Dec 21, 2014 13:54:01 GMT
oscar
Post by oscar on Dec 21, 2014 16:12:05 GMT
Aurmeilius
I'm here this second, but i'm somewhere else a second later.
Post by Aurmeilius on Dec 21, 2014 18:01:01 GMT
Post by Radeg10 on Dec 21, 2014 19:08:58 GMT
Post by RacerBest on Dec 21, 2014 20:23:32 GMT
Post by GunsmokePhoenix on Dec 22, 2014 0:32:59 GMT
