Post by dejanboskov on Oct 7, 2014 12:34:35 GMT
The reventon doesn't have igc version but sesto elemento does have an igc version. I posted some cars(if not all of them) on the EA forum that does have an igc version but they were never released as IGC. Maybe we'll see the gt2 997 since it has an igc version also zonda F has igc version but everything will be revealed in time. You won't see 997 and Zonda F for IGC, those are their top-selling cars. They are literally two A class kings, third one being NISMO. C'mon don't lose hope,be an optimist not a pessimist
Post by Beekilla on Oct 7, 2014 13:31:00 GMT
One thing is being pessimist, other thing is being realist.  But you can sure dream on.
Post by dejanboskov on Oct 7, 2014 16:15:50 GMT
One thing is being pessimist, other thing is being realist.  But you can sure dream on.  Well you know what people says: Dreams comes true so even so I'm still hoping that we'll see some nice cars in igc and maybe some other cars like maserati or range rover or even the vauxhall monaro
Post by Beekilla on Oct 7, 2014 18:39:28 GMT
Post by GunsmokePhoenix on Oct 8, 2014 7:21:07 GMT
Post by kreika on Oct 8, 2014 9:40:40 GMT
Aurmeilius
I'm here this second, but i'm somewhere else a second later.
Post by Aurmeilius on Oct 8, 2014 22:34:32 GMT
GPU
Post by GPU on Oct 9, 2014 7:00:31 GMT
Post by kreika on Oct 9, 2014 10:40:43 GMT
Video Proof? I'm sorry I can't believe your time because you use keyboard, which loses much speed than analog device in corners.
akira
Eat Sleep JDM
Post by akira on Oct 9, 2014 13:51:23 GMT
Post by yuufaisallout on Oct 9, 2014 14:46:27 GMT
It's really everybody's game now, whoever can get the fastest corners exit speed will win XD    4:34.810 - yuufaisallout - Porsche 911 GT2 - 660 - 45 nfstimes.com/nfsw/pc/YUZUHARAINORI
tencha
Pura Vida. Costa Rica. UTD member
Post by tencha on Oct 9, 2014 20:46:40 GMT
I tried to get a better time but is so hard to get 2 good laps in 1 run  ----------------------------------------------------------------------------------- well still not the best time i can get, i think i can get around 4:34.10 if i put my best laps in 1 run    4:34.90 9 - tencha - Porsche 911 GT2 - 660 - 60 nfstimes.com/nfsw/pc/TENCHA1/times
Aurmeilius
Post by Aurmeilius on Oct 9, 2014 22:23:00 GMT
Video Proof? I'm sorry I can't believe your time because you use keyboard, which loses much speed than analog device in corners. What you said is true, but it becomes less true as you go into higher and higher classes and continuously hold the left or right arrow keys instead of tapping them for some of the corners. I did this most notably on the first corner and the S section after the tunnel. Instead of trying to do a whole run (too much effort), I did a hot lap instead. But I think the same point should come across. In some of the corners, I went faster through then than you did (the roundabout for example), and you went faster than me in a few others (like the turn that leads to a slight curve, before the separators). I hope this video can see what you may have done wrong in your run and improve from it as a result. Anyways, here's the video: I hope you enjoyed it.
Post by kreika on Oct 9, 2014 23:34:46 GMT
Video Proof? I'm sorry I can't believe your time because you use keyboard, which loses much speed than analog device in corners. What you said is true, but it becomes less true as you go into higher and higher classes and continuously hold the left or right arrow keys instead of tapping them for some of the corners. I did this most notably on the first corner and the S section after the tunnel. Instead of trying to do a whole run (too much effort), I did a hot lap instead. But I think the same point should come across. In some of the corners, I went faster through then than you did (the roundabout for example), and you went faster than me in a few others (like the turn that leads to a slight curve, before the separators). I hope this video can see what you may have done wrong in your run and improve from it as a result. Anyways, here's the video: I hope you enjoyed it.  thank you. video is ok.
i took some corners badly on lap2, and you did better than me there, as you say  Not only that, you know the best lines to maintain the speed. its like tas xD
Post by PRAS26 on Oct 10, 2014 7:05:53 GMT
