Post by Jussi on Aug 25, 2014 2:17:16 GMT
Track: Waterfront Allowed cars: Class A cars (5 skill mods required) Restricted cars: HERE!Mode: Singleplayer only, Multiplayer and Private match are not allowed Power Ups: None (shield and ready allowed on tracks with traffic). One shot of NOS allowed under special conditions explained HERE!Screen 1: Performance shop showing the installed upgrades and performance values of the car Screen 2: Skill workshop screen showing the 5 skill mods installed on the car Screen 3: Unaltered full size after race screen. Wait for 20 seconds before taking the screen or for the first AI driver to finish Written confirmation: Total time - Driver - Car - Overall - Level (Please USE THE SAME NAME IN ALL CONFIRMATION LINES, even if you use different drivers) The 6th digit: Please update your nfstimes.com page before posting your entry and add the missing last digit to your race time. Notice that SpeedAPI only holds the fastest time per track each day, so never use unallowed cars or powerups before you have updated your competition times. If your page does not pick up your time, explain in your entry why you think this happened. Additional confirmation: All entries have to be recorded at the reference board HERE! (You need to register your drivers for the leaderboard here.) Leaderboard confirmation: In case reference board fails, link to personal leader board at nfstimes.com must be posted below the confirmation line. Unranked times will not be accepted. If you have times that are marked "under the limit", you need to consult the leaderboard staff about it. ISRC 2 membership (optional) : Register for the leaderboards at nfsunlimited.net and join ISRC Leaderboard. Then you can also add www.nfsunlimited.net/leaderboards/team/ISRC below your confirmation line. Deadline: September 1, 2014, Midnight GMT Prizes: N/A or TBA. Note: These rules are subject to change with or without prior notification.Here's an example of the screens you need. They have to be readable size. Please use full size screens with the tags provided below this example. Also do not forget the written confirmation! 4:24.580 - jsskppnn - Lamborghini Gallardo LP 550-2 VB - 733 - 60 nfstimes.com/nfsw/pc/JUSSI/times www.nfsunlimited.net/leaderboards/team/ISRC Jussi _______________________________________________________________________________________Drivers here!
Post by LamboGTR on Aug 25, 2014 11:11:31 GMT
This post is for DQ line reference.
DQ Line 4:31.928 (Thread) DQ Line x:xx.xxx (Leaderboard)
Legend Thread: Time has been proven by being posted on the thread. Leaderboard: Time has been posted on leaderboard but has no post on the thread.
Note: Both times will be the same if time is posted on both.
Post by dejanboskov on Aug 25, 2014 15:37:57 GMT
Here is my entry and I don't expect improvement because I'm going on vacation tomorrow and I won't have an access to pc. Too bad,I have an account that need 4 days for 180 days th and 4 bmw but I can't get to it. 04:26.743 - dejanboskov - BMW M1 Pro Car - 749 - 56 nfstimes.com/nfsw/pc/APKAH123/times
AQ9
NFSW Veteran
Post by AQ9 on Aug 25, 2014 17:59:51 GMT
Gigaxero
Its all about the driver
Post by Gigaxero on Aug 25, 2014 18:47:56 GMT
Niqht
Post by Niqht on Aug 25, 2014 22:09:58 GMT
Post by yuufaisallout on Aug 26, 2014 15:05:05 GMT
AQ9
NFSW Veteran
Post by AQ9 on Aug 26, 2014 19:30:16 GMT
Post by ianism on Aug 27, 2014 3:07:50 GMT
I can't believe how good this Jaag is. 3 hours of practice. I'm done, I probably just did my best run ever. Maxxed ram skill helps a lot here and it's better than an extra 2 seconds of PS (knowing the jaag is non-cosmic). This track is full of nasty obstacles. i'm surprised more people aren't using it. i am going to use it or a stock agera for this track. i don't actually know which will be faster
AQ9
NFSW Veteran
Post by AQ9 on Aug 27, 2014 4:06:37 GMT
i'm surprised more people aren't using it. i am going to use it or a stock agera for this track. i don't actually know which will be faster I'm pretty sure an Agera can easily do under 4:09. Cosmic Nos and better handling would help for sure but the XKR is heavier and much more stable on jumps which is a plus in Waterfront
Post by ianism on Aug 27, 2014 13:05:35 GMT
i'm surprised more people aren't using it. i am going to use it or a stock agera for this track. i don't actually know which will be faster I'm pretty sure an Agera can easily do under 4:09. Cosmic Nos and better handling would help for sure but the XKR is heavier and much more stable on jumps which is a plus in Waterfront i am not such a pro driver, so i will probably have an easier time with the XKR. and the perfect start shouldn't be such a big deal on a long track like this, no?
AQ9
NFSW Veteran
Post by AQ9 on Aug 27, 2014 14:01:45 GMT
i am not such a pro driver, so i will probably have an easier time with the XKR. and the perfect start shouldn't be such a big deal on a long track like this, no? You can try the CCX Elite, if you have one. I drove it, it proved to be a lot better than the stock CCX, weight and stability wise. I'll see how much I can do with it
Post by ianism on Aug 27, 2014 23:53:14 GMT
You can try the CCX Elite, if you have one. I drove it, it proved to be a lot better than the stock CCX, weight and stability wise. I'll see how much I can do with it ew, no i wouldn't touch the elite cars with a 10-metre pole.
Nelro
Admiring the Craftsmanship of Nismo Engineers
Post by Nelro on Aug 28, 2014 7:09:24 GMT
I did so slow, but the 90deg. corner into the amusement park is hard to take on. Have to blame my skills. 4:23.743 - NELRO - BMW M3 GTS - 741 - 60 nfstimes.com/nfsw/pc/NELRO/times
Post by Radeg10 on Aug 28, 2014 16:22:16 GMT
I tried my S class R8 LMS at zero durability, at 749 it should be good
