Post by Jussi on Apr 18, 2014 19:17:33 GMT
Post by nevermemos on Apr 19, 2014 10:07:45 GMT
Post by Chandrian on Apr 19, 2014 11:16:00 GMT
GT40 is not so bad what parts are you using on that gt40? While watching this video to take a screenshot I also noticed the lack of obstacles (which really makes this a hard turn if not taking the shortcut); I have very impressive artistic abilities How do you get rid of obstacles once again xD? I tried setting the graphics to minimum settings and then restarting the game, but that doesn't work D:
Post by andsoclean on Apr 19, 2014 12:14:08 GMT
GT40 is not so bad what parts are you using on that gt40? While watching this video to take a screenshot I also noticed the lack of obstacles (which really makes this a hard turn if not taking the shortcut); I have very impressive artistic abilities How do you get rid of obstacles once again xD? I tried setting the graphics to minimum settings and then restarting the game, but that doesn't work D: Low settings. It's obviously a glitch or else it would also apply for Minimum settings.
Post by RacerBest on Apr 19, 2014 13:16:32 GMT
Stupid glitch helps here again -.- Never used it and won't use it here either.
Post by Chandrian on Apr 19, 2014 14:21:12 GMT
Stupid glitch helps here again -.- Never used it and won't use it here either. I'm not using it either, but there's people who are using it, so we're in a disadvantage and we're forced to use it.
Post by DerpyMail on Apr 19, 2014 14:34:20 GMT
While watching this video to take a screenshot I also noticed the lack of obstacles (which really makes this a hard turn if not taking the shortcut); I have very impressive artistic abilities There is supposed to be a pack a garbage here? Well, never seen it before, but I noticed a huge lag spike that slows me down when I get on that turn. Oh well.
Post by Radeg10 on Apr 19, 2014 15:13:09 GMT
what parts are you using on that gt40? GYB-G- I used green brakes just for get 499 OA but i think it brakes worse than without brakes. I also tested YGY--- while ago and got almost same time but with 0% bug Setup from Lambo´s guide is not good for this car IMO. GT40 MK I has peak power at 7.000 RPM and torque at 5.500 RPM (wikipedia) so GYB should be fine. LamboGTR fix your guide .
Post by Chandrian on Apr 19, 2014 15:49:28 GMT
what parts are you using on that gt40? GYB-G- I used green brakes just for get 499 OA but i think it brakes worse than without brakes. I also tested YGY--- while ago and got almost same time but with 0% bug Setup from Lambo´s guide is not good for this car IMO. GT40 MK I has peak power at 7.000 RPM and torque at 5.500 RPM (wikipedia) so GYB should be fine. LamboGTR fix your guide . Yep, that's why I asked, because I was using lambo's parts and it sucks will try yours tonite!
Post by un1que on Apr 19, 2014 16:53:23 GMT
Gonna be dead last in this event....no time whats so ever lol
~The Watcher
PS: will try to update later on tonight
Post by nevermemos on Apr 19, 2014 18:56:45 GMT
Post by LamboGTR on Apr 19, 2014 20:20:52 GMT
GYB-G- I used green brakes just for get 499 OA but i think it brakes worse than without brakes. I also tested YGY--- while ago and got almost same time but with 0% bug Setup from Lambo´s guide is not good for this car IMO. GT40 MK I has peak power at 7.000 RPM and torque at 5.500 RPM (wikipedia) so GYB should be fine. LamboGTR fix your guide . Yep, that's why I asked, because I was using lambo's parts and it sucks will try yours tonite! My setups wont work for some people on some cars..its cool Change a few parts till you're happy. Rade the YYG setup works because its a V8 with mid range torque. GYB might work better for you due to the shorter gears and low torque allowing you to turn a bit better.
Post by bumbilek on Apr 20, 2014 4:07:21 GMT
nekholu
Post by nekholu on Apr 20, 2014 6:57:04 GMT
Post by davidpage on Apr 20, 2014 8:44:33 GMT
