Post by Jussi on Feb 11, 2014 14:20:14 GMT
Post by dejanboskov on Feb 11, 2014 15:21:40 GMT
I've changed my set up but still not enough 02:10.329 - dejanboskov - CHEVROLET COBALT - 399 - 42 nfstimes.com/nfsw/pc/MP3A/timesnfstimes doesn't want to pick up that timing so I'll wait or I think I could improve this by 1 or 2 sec. edit:lowering the quality I improved the timing so now it will be hard to be dq time now will be edited,but those pics from before along with this new one will stay.
Post by LamboGTR on Feb 11, 2014 16:25:10 GMT
Nice man! You are safe unless someone beats 1:57.296
vidia
Clean race,pls...rammer=beginner, childish driver!!!
Post by vidia on Feb 11, 2014 16:29:00 GMT
Post by dejanboskov on Feb 11, 2014 16:29:27 GMT
Nice man! You are safe unless someone beats 1:57.296 I need to learn the track little bit more and try to handle the car nicer
Post by FasterthaMyou on Feb 11, 2014 17:12:25 GMT
Any one want to test the difference between Super Bee (original) and Super Bee Juggernaut? Jussi I will look into this. I came up with this. The J-naut is a good deal heavier and more difficult to drive.
Post by un1que on Feb 11, 2014 17:49:59 GMT
Any one want to test the difference between Super Bee (original) and Super Bee Juggernaut? Jussi I will look into this. No need too Lambo has one on his ch it was vs me for an old black list match ~The Watcher
Post by RacerBest on Feb 11, 2014 18:34:16 GMT
Ryu MakkuroIf the game goes smooth, 30 fps and 100 fps don't have any difference in performance. I have done top time for ISRC event too, while recording 30 fps video and I am not a cheater. Here is the video, for some weird reason the video doesn't work now, I don't know if it will work later.
GTSF
Post by GTSF on Feb 11, 2014 21:24:52 GMT
Just a quick reply with some R.Turnpike times done in autogear with LP650 having a overall of 752.
My PC configs: Intel P D 3GHz, 2GB DDR2 Ram, 512MB Nvidia Geforce GPU, 1mbps internet connection with 40-50ms average ping. And I play on LOW graphics and get a average of 30 fps.
I started in LOW and changed to different settings and times are below: Low: 12.23, 12.21, 12.36, 12.40 Minimum: 12.17 Low: 12.14(!), 12.42(!) Minimum: 12.40, 12.40, 12.37, 12.36 Medium: 12.40, 12.40, 12.42 Low: 12.17, 12.19
Usually on Low setting it gives me 30 fps average, way above 30 on Minimum with 800x600 res and around 20-25fps on Medium. I tested this fps thing long ago with Fraps which miserably failed to record video on this PC lol
So all these times means anything? Thats quite a variations right there! And I think low setting or low fps isn't a factor but the ea nfsw servers or the internet connection is.
Post by XDXDXDXDXD on Feb 11, 2014 21:48:59 GMT
hahaha I do not know if you are newbie or not see my video ... Do you know how long it took me to make that time? It took me two hours ... I think you need buying a good friend lenses! And you need to learn some people are experienced enough to know what is possible and what's not. Your run was perfect, that is true, but mine was as well. And since you play at those FPS, going below 2:00 mark is impossible, due to the simple fact that the game makes you slower. Increased FPS does not mean increased performance. Having better FPS makes it easier to do better times, but it does not directly effect the speed of the game. I know in Rivals when it was first released that increasing the FPS increased the speed of the game - But that is definitely NOT the case in World. I've had it running at 100 FPS before and it made no difference. I consistently run at 85 FPS now, simply to provide a 'buffer zone' for when the FPS drops (hoping that when it does drop, it doesn't go below 60 FPS and become noticeable to my eyes). HOWEVER - The 'speed bug' happens when the game falls out of sync because of memory issues (same thing for the 'slow bug', just those unlucky people get the reverse effect). JANOGT1 seems to have a slower computer, so it is possible that he runs in to the speed bug more often since memory issues will be more prevalent in a slower computer. He's not the first and will not be the last member on this board to get great times with the speed bug. Increased FPS, or rather FPS over 60 does mean increased performance. Simple test is enough, automatic gear box with the same car on Turnpike. Do runs at 30FPS and then at 80+ FPS and you'll see that there will be a difference in times. As I said, in a 1 minute track that is not top speed based, it's about 1 second slower time. There's nothing you can do about it, game does make put out actual performance only when you're above 60FPS. When you are below you have worse performance. Like an FPS slowbug or something. I think that recording program works different. It shows the fps the recorded video is being processed at, not the fps your game is running at, which is totally different; dxtory works that way, for example. The program is called mirillis action. I know about that very well, thus it has TWO FPS counter, one shows Video framerate and second actual FPS in-game, both of which show below 30FPS. I am a YouTuber and I have used my fair amount of recording programs so I do know my way around with them. I know jano and is a clean player, time is possible That coming from you makes him even less reliable -.- And before someone starts saying "jealous", "crybaby" and so on, I joined not for rewards, but for fun, fair play and competition. So when I see a cheater I simply inform about it. I don't accuse people of cheating because "I want to win", but because they actually cheat. I could care less if someone would beat me, I would actually be happy, but not when someone does that in a cheating way. You may say I come here and say who cheats and who not, but I did experience few times already what it means to be fooled by your so called "friends", thus I don't believe in explanations like "he's my friend, we always race and he is beatable", cause when you don't race with each other, those people start to cheat. And it so happens I find some of them while they are doing it. Anyway, this will most likely be my last post here, seems that my presence is like a magnet for cheaters -.- You're a Newbie I have nothing to fear if you knew me ... you would not be so, friend!
Post by Lycain on Feb 11, 2014 22:05:22 GMT
Hello there Guys! Good luck to all of you for this amazing Event! It looks Jano busted my theory! Action has nothing to do with the Car Performance! I am really glad being wrong best of luck to all of you again!
Ryu Makkuro
Powered by DragonForce
Post by Ryu Makkuro on Feb 11, 2014 22:46:15 GMT
You're a Newbie I have nothing to fear if you knew me ... you would not be so, friend! Yeah, I explain everything properly, and then you have a "Newbie" reply, which can be taken as an insult -.- Of course you have nothing to fear, it's not like I can ban you or something. Hello there Guys! First of all good luck to all of you for this amazing Event! Just before few minutes i was talking with Ryu (we are close Friends and we share thoughts and opinions) He clearly told me that Jano was cheating i say well there is lots of people who say he is Clean! Also i ask him to let me see that Video and then we can talk! When i saw he was using Action everything was clear to me! Im not into tech all i have is my experience to all the cars i own in Game and how they behave! From the Acceleration to the Handling and overall Performance! My Case was this when i started using this application ( Action) i notice (so the other Players) a small difference to how the Cars Perform! It wasent me only i did this test lots of times and People started to call me cheater i dont know if it was the combination of my crap PC and low FPS but i was almost sure that the Car has something MORE! I showed a video to Ryu a recent one with my UltraBook and he was really surprised he actually said. "[11:36:07 μμ] Ryu Makkuro: it does look a bit too fast for D class indeed" All i wanted is to Clear that thing that Jano maybe he didnt use something and he is not a Cheater and maybe is the just the application (Action) that caused this issue! I still have the Action never cheated and never will. I have to ask from all the fine people here to test this application and prove me wrong! Since i have nothing to fear here is the Video i showed to Ryu! www.youtube.com/watch?v=Sch5vpCx-dk Thats All! Kindly Bell! What Bellie said here may be true, but then it would mean that recording program can work as a speedhack... which would compromise World even more, and that program as well I suppose (in a small way of which no one would really know). Anyway, it's either that, speedbug or speedhack as that time is definitely not possible at that amount of FPS. If you guys/ladies want, I can show the Skype talk with Bellie, the entire part of it when it comes to talking about this "incident". And to show I'm not "envy" or "jelly", please ignore my entry, disqualify it or something, in other words it's not to be included at all. As I said, I join for fun, fair play and competition, and I try to look for everything that is not fair towards others.
Post by Radeg10 on Feb 11, 2014 22:53:16 GMT
Done with my broken kb and Im too much drunk for anything faster hate bday
Post by un1que on Feb 11, 2014 23:37:49 GMT
Not gonna try to hard in this one.....not my track it seems round 2 come quicker lol ~The Watcher
Post by FasterthaMyou on Feb 12, 2014 0:00:44 GMT
Time to let the big boy out lol 2mins should be easy for all of us What happened to this, my good friend?
