Post by FasterthaMyou on Dec 31, 2013 1:20:37 GMT
Jussi, This is a beautiful car. Are those the original rims? Did you strip a "Rose" or "Snowflake" version of the 911 Turbo to get this car?
vidia
Clean race,pls...rammer=beginner, childish driver!!!
Post by vidia on Dec 31, 2013 8:49:10 GMT
Post by PRAS26 on Dec 31, 2013 12:18:21 GMT
Removed some parts from Europa, made it 599 and got this time after a few runs.. 1:33.952 - pras8826 - Lotus Europa S - 599 - 60 nfstimes.com/nfsw/pc/PRAS26
Post by Lycain on Dec 31, 2013 12:50:57 GMT
Post by LamboGTR on Dec 31, 2013 13:50:02 GMT
Tried out GTSF's idea about a stock M3 but the car is just so slow.
Post by Chandrian on Dec 31, 2013 15:47:40 GMT
LamboGTR Elise is faster than M3 E46 in my opinion. Accels better. I'm getting times decent enough with mine, but I'm kind of strugling with the 30º corner, as it seems that the car doesn't handle good enough while braking; any tips? >_< Leaderboard doesn't want to pick up this or any of my recent times at that track.
Post by Jussi on Dec 31, 2013 16:17:10 GMT
Post by LamboGTR on Dec 31, 2013 16:24:40 GMT
LamboGTR Elise is faster than M3 E46 in my opinion. Accels better. I'm getting times decent enough with mine, but I'm kind of strugling with the 30º corner, as it seems that the car doesn't handle good enough while braking; any tips? >_< Leaderboard doesn't want to pick up this or any of my recent times at that track. Tap handbrake as you brake and correct right if you oversteer too much. Go for a exit speed of 120+ KPH
Post by Chandrian on Dec 31, 2013 16:52:26 GMT
Tap handbrake as you brake and correct right if you oversteer too much. Go for a exit speed of 120+ KPH I'll try that, though as Elise has good handling, I thought I should aim for higher speeds, something like 130 or even 140 for corners like that one :/ Also, I did notice that I have no problems at handling while braking with some of my cars, most of which got either green or blue brakes on. And that I strugle with the cars that got red or yellow brakes on them. So I'll try what you said, but I'll also try changing the brakes color
Post by LamboGTR on Dec 31, 2013 16:56:57 GMT
Tap handbrake as you brake and correct right if you oversteer too much. Go for a exit speed of 120+ KPH I'll try that, though as Elise has good handling, I thought I should aim for higher speeds, something like 130 or even 140 for corners like that one :/ Also, I did notice that I have no problems at handling while braking with some of my cars, most of which got either green or blue brakes on. And that I strugle with the cars that got red or yellow brakes on them. So I'll try what you said, but I'll also try changing the brakes color Try green. They are the weakest so they should give you the least amount of brake understeer.
Post by Jussi on Dec 31, 2013 17:47:33 GMT
Jussi, This is a beautiful car. Are those the original rims? Did you strip a "Rose" or "Snowflake" version of the 911 Turbo to get this car? It's a snowflake and those are stock wheels in metal white color. It's a tough decision between the gay flare and female driver, but I guess I'll rather be a little gay than a transvestite. All ultra tuned, by the way. This is full street tuned (tires are green). 1:33.239 - jsskppnn - Lotus Elise - 599 - 60 nfstimes.com/nfsw/pc/JUSSI/times www.nfsunlimited.net/leaderboards/team/ISRC Jussi
Post by bumbilek on Dec 31, 2013 19:58:54 GMT
Post by nevermemos on Dec 31, 2013 20:39:00 GMT
Post by dejanboskov on Dec 31, 2013 21:12:50 GMT
01:31.999 nfstimes.com/nfsw/pc/DEJANBOSKOV/timesI won't write the rest because this car is not EU car but just to show u that if I can make it 5 seconds boost on this I can do under 1.31 with a car similar to the boss great, but that's sub-1:32 not sub-1:31 well I have 2 seconds boost on that boss so I got almost 1.32. If I can max it to 5 it would be different story.
Post by Chandrian on Jan 1, 2014 0:14:12 GMT
Try green. They are the weakest so they should give you the least amount of brake understeer. Meh, doesn't change anything, though it does on cars like RX-8 '09, oh well. But I learned to take the corner properly with your help and got a 1:30.490! Woohoo. Will try getting it down to below 1:30
