Post by GunsmokePhoenix on Dec 3, 2013 12:10:32 GMT
Post by ianism on Dec 3, 2013 12:11:08 GMT
^^ very nice time jussi! i wasn't able to get under 2:15.50 with that car
Post by dejanboskov on Dec 3, 2013 12:14:41 GMT
I know that this car don't belong in this class but this and the lfa are the only s class in my garage and the miura concept is hard to make it in S class since I'm igs player and I can't sell the unique cars I have so anyway I couldn't do under 2.30 this I managed to do barely so here it is: 02:29.920 - DEJANBOSKOV - Porsche 911 GT3 RS 4.0 - 784 - 60 www.nfsunlimited.net/world/user/DEJANBOSKOVnfstimes.com/nfsw/pc/DEJANBOSKOV/times
Post by ianism on Dec 3, 2013 13:05:41 GMT
...how is your route different from what you did before? that is identical to what i do, except with better driving
Post by LamboGTR on Dec 3, 2013 13:31:48 GMT
...how is your route different from what you did before? that is identical to what i do, except with better driving 1. I go around on the second shortcut. 2. I hug the guard rail on the right as you exit the tunnel..before I went wide 3. I braked early at the blue wall people use to wall ride and hit the sign. Before I went wide. 4. I cut in before the last lamp post on the road leading to the right before the jump. 5. I squeeze in between the wall and the booth on the jump.
Post by anandvmaster on Dec 3, 2013 13:49:51 GMT
MIB
Post by MIB on Dec 3, 2013 15:14:07 GMT
Post by andsoclean on Dec 3, 2013 15:44:06 GMT
...how is your route different from what you did before? that is identical to what i do, except with better driving 1. I go around on the second shortcut. 2. I hug the guard rail on the right as you exit the tunnel..before I went wide 3. I braked early at the blue wall people use to wall ride and hit the sign. Before I went wide. 4. I cut in before the last lamp post on the road leading to the right before the jump. 5. I squeeze in between the wall and the booth on the jump. The difference between using Minimum and Low vs. Medium and High graphic settings; 1. I go around on the second shortcut. There's a light post where your driving line is at the right turn after that section.
2. I hug the guard rail on the right as you exit the tunnel..before I went wide There are barrels in the road along the side closer to the rail
3. I braked early at the blue wall people use to wall ride and hit the sign. Before I went wide. --- No difference, beautiful turn.
4. I cut in before the last lamp post on the road leading to the right before the jump. There's more crap along the outside of the street
5. I squeeze in between the wall and the booth on the jump. --- No difference, nice squeeze I wish I could try with Minimum or Low settings to compare driving lines but my computer runs like crap if I'm not on Medium or High. (Odd, I know, but I'm not going to look into it since I like the better graphics anyways.)
Post by nevermemos on Dec 3, 2013 15:48:54 GMT
Post by LamboGTR on Dec 3, 2013 16:47:29 GMT
1. I go around on the second shortcut. 2. I hug the guard rail on the right as you exit the tunnel..before I went wide 3. I braked early at the blue wall people use to wall ride and hit the sign. Before I went wide. 4. I cut in before the last lamp post on the road leading to the right before the jump. 5. I squeeze in between the wall and the booth on the jump. The difference between using Minimum and Low vs. Medium and High graphic settings; 1 I see the light post too O.o
Post by andsoclean on Dec 3, 2013 19:35:58 GMT
The difference between using Minimum and Low vs. Medium and High graphic settings; 1 I see the light post too O.o I meant the first turn but now I'm not seeing some of the same obstacles I did before switching back from Low settings to High... Whaaaaa....
Post by PRAS26 on Dec 3, 2013 20:42:22 GMT
I see the light post too O.o I meant the first turn but now I'm not seeing some of the same obstacles I did before switching back from Low settings to High... Whaaaaa.... Switching to higher graphics needs a restart to get some of those extra details. Sometimes going in and out of safe house does the job but not always.
Post by un1que on Dec 3, 2013 23:20:28 GMT
I got 2:11 with the zonda F Gonna try doing it in Low settings since you guys are playing around with them
Post by GustavoAP on Dec 4, 2013 3:09:39 GMT
Post by ianism on Dec 4, 2013 7:01:16 GMT
I got 2:11 with the zonda F Gonna try doing it in Low settings since you guys are playing around with them i only have it because my computer can't handle medium or higher unless i'm in freeroam
