Post by Chandrian on Oct 24, 2013 17:31:16 GMT
To verify you did the time with a sp race. But the single player opponent names are seen in the right side of the screen so I don't think that's very important anymore. When that rule was made you couldn't see the race HUD behind the post-race screen. Yeah well there's also the rule of posting garage screens of both skillmods and parts installed in your car, even though after the car classes we got the option to show them at the post-race screen too.
Post by RacerBest on Oct 24, 2013 18:16:31 GMT
Performance shop picture is useless too, but skills workshop picture is the only way to see what amount of each skillmod the driver had.
rie
Post by rie on Oct 24, 2013 18:31:49 GMT
To verify you did the time with a sp race. But the single player opponent names are seen in the right side of the screen so I don't think that's very important anymore. When that rule was made you couldn't see the race HUD behind the post-race screen. Ah that's true. Now that you mention it, it isnt that important anymore imo.
Post by Paragleiber on Oct 24, 2013 20:31:43 GMT
Post by Jussi on Oct 24, 2013 22:03:16 GMT
If Racerbe5t didn't use powerups, the 110% DQ line is at 2:47.662 now! Jussi
Post by ELRIO77 on Oct 24, 2013 22:08:13 GMT
If Racerbe5t didn't use powerups, the 110% DQ line is at 2:47.662 now! Jussi That run shaded almost 2.5 seconds off the DQ time.
Post by RacerBest on Oct 25, 2013 4:49:21 GMT
If Racerbe5t didn't use powerups, the 110% DQ line is at 2:47.662 now! Jussi I didn't. 2:32.04 is my best time, and I have 2:32.60 on video. I try to make better time on video today if I can. I don't even usually make videos of my runs, but I was already told "no way that is legit", so I want to prove that it is.
Post by Jussi on Oct 25, 2013 6:26:45 GMT
I wonder if I should try lower graphics settings? My game lags at Rockport Center area. Jussi
Post by Jussi on Oct 25, 2013 6:36:37 GMT
If 110% is too tough, the 111% point is at 1:48.76662 ATM. If GustavoAP can not make 1:47.2462, I may have to use 111% instead. He has entered every race since he joined, so it would not be fair to set the bar out of his reach. Jussi
Post by Chandrian on Oct 25, 2013 10:43:38 GMT
Jussi, I edited your post for your own safety, lol.
Post by nevermemos on Oct 25, 2013 14:27:44 GMT
I don't have ultra parts to put them on my scirocco so this is the best i can do with this OA (Jussi the time i did currently doesn't show up, give it some time and will appear..i think) 2:37:90 - Nevermemos - VW Scirocco - 475 - 60 nfstimes.com/nfsw/pc/Nevermemos
Post by Jussi on Oct 25, 2013 16:05:43 GMT
(Jussi the time i did currently doesn't show up, give it some time and will appear..i think) Last times check 10 hours ago... Didn't you update your nfstimes page? Jussi PS. I accidentally edited your message trying to quote it.EDIT: I updated the page for you and the time showed up.
Post by RacerBest on Oct 25, 2013 16:45:43 GMT
Here is a video of 2:32.35. Beautiful quality warning. Video recorded half size (of 1280x720) and 15 fps.
Post by pumpedupkid on Oct 25, 2013 17:08:33 GMT
Post by andsoclean on Oct 25, 2013 17:20:39 GMT
Here is a video of 2:32.35. Beautiful quality warning. Video recorded half size (of 1280x720) and 15 fps. Nice run... I'm not sure where I'm losing time since a lot of turns in that video were pretty much taken at the same speed that I do Unless your part setup really makes that much of a performance difference. (I think that might be it because the very first turn before the long straight I usually take around 130-135kph but you ended up hitting 271 kph when I can only hit 267 by the end) Now I actually want to try using my R32 again and see what's the deal... Curse you! Boss times.
