Post by Bandit (PC/PS3/4) on Sept 22, 2009 16:53:17 GMT
So i want to change the CD-Key for Shift and i thought there might be an executable for changing the CD-Key but i can't find it anywhere.. Anyone knows if it is even possible to change the CD-Key? Thanks, Bandit
Post by VGSpeedPro on Sept 22, 2009 17:21:33 GMT
Hi mate! It is... I am not at home at the moment, so I can only tell you what I remember... In Vista, you start regedit.exe. Then in Local Machine, you go to Software and then Electronic Arts... Now the key is not in the NFS Shift that we think it is... Is in the branch of the tree directly on top, under rcpl or something similar... Hope this helps... Rogério
Post by Bandit (PC/PS3/4) on Sept 22, 2009 17:54:39 GMT
Thanks Rogério! Though that didn't help me out, i actually found the CD-Key changer executable ... Now i can finally go online! - After i have patched the game Bandit
Post by VGSpeedPro on Sept 22, 2009 18:02:07 GMT
That exists? Where is it? I will have to do the same when I get home probably... Going to try to buy the Game when I leave work! Rogério
Post by Bandit (PC/PS3/4) on Sept 22, 2009 18:09:42 GMT
Hehe It's in the "Support folder" in the main Shift directory.. It's called: "Need for Speed Shift_code" and it's an application I even altered the code when i was still running the game and no problemo whatsoever when i restarted the game! Still need to patch it though... Goodluck, Bandit
Post by Grnkjr0 on Sept 22, 2009 18:16:40 GMT
Post by Jussi on Sept 22, 2009 18:56:47 GMT
It's here in Vista's Regedit: HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\Electronic Arts\Need for Speed Shift\ergc Jussi
Post by Bandit (PC/PS3/4) on Sept 22, 2009 19:26:18 GMT
Enough said .. Might want to lock this one since i'm unable to since ISRC II ...
