Post by TheGreenMonster (PC) on Sept 25, 2009 18:50:07 GMT
How do I perform a clean lap on a one lap race? I start in back of at least a 20 car pack. What kind of tricks do I need to do to over come this problem. Monster
Post by jeffareid on Sept 25, 2009 19:52:34 GMT
How do I perform a clean lap on a one lap race? You should be able to get credit for the clean lap part by doing a quick race with no AI opponents, then run the career event. Most of the "bonus" stars, such as 800 points, 1600 points, master corner, will carry over from quick race runs done on the same track, when you run the career event. There's also a trainer that has a feature similar to "resetya" from High Stakes. It causes all the AI cars to flip upwards into the air, and you can drive through or around the carnage depending on the track. However it's a cheat happens trainer which requires membership, until another similar trainer is released. On a side note, you can do a quick race with zero AI opponents, yet still get credit for a podium finish with AI difficulty set to hard. If you want to run up driver points, set AI to "easy", then do a 20 lap quick race at Dakota Tri-Oval with 1 opponent, using the loaner Maserati MC12 if you don't have a supercar. Follow the racing line and the AI car for the first 18 laps, then pass to win the event. Good for about 7,000 to 8,000 points. If done at the start of career the driver level up will result in $45,000 on the first run and $105,000 ($45,000 + $60,000) on the second run. The third run won't help directly though. Leveling up also unlocks invitational events, and you get a lot of precision points (racing line) and aggression points (drafting) for doing the Dakota run with the 1 AI car.
Post by VGSpeedPro on Sept 26, 2009 0:12:47 GMT
About winning points, doing the Nurburgring will allow over 10k per run... Maserati can do it well under 7m...
Post by xxxh0tridexxx on Sept 30, 2009 18:22:57 GMT
Some pictures Nissan R34Technical Data - Top Speed 468km/h - Speedup 0-100km/h @ 1,79sec Testdrive -digital display 298km/h -analog display 308km/h Nissan 370z2nd round for the needle
