Post by rcgldr on Apr 12, 2011 19:25:30 GMT
If you're mid race and achieved a goal, such clean lap, you can abort and restart the race, and still get credit for the clean lap (it won't show up during the restarted race even if you do get another clean lap, but it shows up at the end). This doesn't work for the Nordschleife events, most of which are sprints or only 1 lap, since you'd be doing a normal race again to redo those.
Note that these goals don't affect career progress. You can reach 100% complete even if you don't get all the event objectives like 4 second drift, clean lap, ...
Post by skroting on Apr 12, 2011 19:32:34 GMT
Good to know. Also good to know that I don't need to do all these boring "missions", but to get 100 % I still have to do the damned drifts and the eliminator. You wouldn't think that the latter would be so bad, but I just can't take the beeping. Why did they make the clock beep for every second even when there is two minutes left until elimination?!
Post by rcgldr on Apr 12, 2011 19:59:51 GMT
To get 100 % I still have to do the damned drifts and the eliminator. I found a drift cheat table for cheat engine (or any trainer that has an increase value hotkey function), address is 0xedfa78. There are probably pre-made trainers also, but I haven't looked for one yet. For the eliminator you could turn down the sound?
Post by skroting on Apr 12, 2011 21:10:10 GMT
If I'm going to get 100 %, then it's not because I just want the number there, I want to do it all, but drifting needs to be "fixed" first.
I suppose I could turn down the sound, but then I'd also turn down sounds I want to hear. Maybe that's more tolerable than I thought to begin with. I'll give it a try just to see how it is.
Post by rcgldr on Apr 13, 2011 20:04:24 GMT
If I'm going to get 100 %, then it's not because I just want the number there, I want to do it all, but drifting needs to be "fixed" first. I think of it as personalizing career mode for yourself. Seems there are multiple sound volume settings, so maybe you can turn that one down without affecting the others. I set the music to low or off.
