Post by Jussi on Apr 16, 2011 20:43:13 GMT
Post by TheGreenMonster (PC) on Apr 17, 2011 2:27:27 GMT
Having a few beers instead of racing.... these youtube video's don't post anymore why? ... here a song called 10 little bottles youtu.be/3s9qx6pJBvc
Post by Soul Traveller (PC, PS3) on Apr 17, 2011 3:12:37 GMT
1:58:917 - Soul Traveller - Nissan GTR(R32) - D499 - 57.151
Post by micrak on Apr 17, 2011 10:34:18 GMT
Mazda RX-7 for Monza Jr Upgrades: from left to right from top to down I am looking for translations of the Upgrade Parts( I need help my english is not good ), I hope you understand my list! 263kmh topspeed,great acceleration , bad brakes ,poor handling .I think someone like Aaron, improves handling I have not yet look at the telemetry ,no idea of the tire temperatures .I think tires are the problem !I am thankful for tips and also for feedback. www.youtube.com/watch?v=vqyomv_RkogMotor 1 1-1 2-2 3-3 4-2 5-2 6-- Antriebsstrang 2 1-3 2-1 3-3 Turbo3 1 Fahrwerk4 3 Bremsen5 1-3 2-3 Reifen6 1 Karosserie7 1-- 2-- 3-2 Nitro8 2 F tire pressure - 48.00 R tire pressure - 43.00 Brake balance - 48.00 Brake pressure - 4.00 - Steering lock - 22.00 Caster - 6.00 F toe - 17.00 R toe - 22.00 F camber - 45.00 R camber - 52.00 - F & R ride height - 1.00 - F & R downforce - - - Limited slip preload - 3.00 - F damper fast bump - 1.00 F damper slow bump - 4.00 F damper fast rebound - 5.00 F damper slow rebound - 5.00 R damper fast bump - 1.00 R damper slow bump - 2.00 R damper fast rebound - 1.00 R damper slow rebound - 1.00 - F sway bar - 9.00 R sway bar - 7.00 F spring rate - 4.00 R spring rate - 4.00 F bump stop - 3.00 r bump stop - 3.00 - Final drive - 3.00 1st - 1.00 2nd - 3.00 3rd - 3.00 4th - 1.00 5th - 2.00 Mic
Post by Grnkjr0 on Apr 17, 2011 11:59:46 GMT
Micrak why do you not change the in game language from german to english? It sure will help one to understand english better.....
Post by rtxus (PC) on Apr 17, 2011 12:59:34 GMT
Language change: open regedt32.exe goto Hkey current user, control panel, international and modify: LocaleName to de-DE or en-EN etc, works with all Languages You have in shift2 Audio folder..
Thanks for the set, ill give a try later if i have time.
Marco
Post by Jussi on Apr 17, 2011 17:01:17 GMT
Wish I had time to test that RX-7 setup, but it's election day and I also have the F1 GP waiting to be watched, so I'll be nailed in front of the TV instead. Jussi
Post by aarog5606 on Apr 17, 2011 17:13:40 GMT
Post by rtxus (PC) on Apr 17, 2011 18:41:29 GMT
next improvement, mics parts, just changed my tuning to camber as micrak (incredible how this change my speed) and swaybars. Far from a perfect lap, a second faster must be possible... 1:44.745 - rtxus - Mazda RX7 (FC3S ) - rating 496 - best lap 49.690 Marco
Post by paul on Apr 17, 2011 18:45:58 GMT
Hey, while I can't compete with legal enrtys, I've tried micrak's part and did few laps here - awesome work with the parts, mic ! In 2nd lap I did huge mistake, I think flat 1.44 shouldn't be problem for good race. Video of my test drive : Paul
Post by micrak on Apr 17, 2011 21:36:29 GMT
Hey Racer,i cant faster. Paul congrats incredibly fast , i saw in your video you have more topspeed ,do you have a different gear ratio? my fastest of the week 1:44.665 - micrak - Mazda RX7 (FC3S ) - rating 496
Post by paul on Apr 17, 2011 22:09:31 GMT
Hello mic, I have stock gear ratios, everything in middle, but I have some other engine parts ... maybe larger injectors to lower engine rpm - this make car faster with the same gear ratios. My rating is 499 and I have brakes at lvl 2. If you want, I'll write you my parts changes Paul
Post by Jussi on Apr 18, 2011 7:22:31 GMT
Will be interesting to see, if anyone was able to reach higher driver classification in this race. I'll do the math after David (or someone else) has gathered the results. Jussi
Post by micrak on Apr 18, 2011 7:42:33 GMT
Hi Paul ,good tip :larger injectors to lower engine rpm !I will remember for the next C, D class PBRC .My gear ratio was the previous setup with less horsepower.Now you finally get that game ! Thx Marco ,Your tip with the tires was essential. Michael
Post by paul on Apr 18, 2011 10:14:32 GMT
It wasn't larger injectors, it was high flow fuel pump and filter, but i think the injectors will work as well Differences in my setup - Engine : 1-2 2-2 3-2 4-2 5-2 Brakes : 1-2 2-3 I'm not sure, which setup is better, if softer settings or stiffer. I set only softer sway bars and upgraded a bit toe angles and cambers, so the car could be more stable while breaking. For next event at Ebisu South will be this setup useless, this is such a curved track. Both first sectors was in record time, but second sector in second lap was a bit slower. Paul
