Post by aarog5606 on Apr 21, 2011 12:23:09 GMT
I'm not so sure about how the setups are working. With a works LP640, I tried tire pressures at 40/40, 40/50 and 55/70 (front/rear) at Nordschleife. The feel was a bit different but lap times were about the same (around 5:56.5 for me which seems to be my limit. At Willow, the 55/70 pressures resulted in a bit better lap times, but it didn't seem to help at Nordschleife. Using Willow Springs turn 2 as example, at 40/50 corner speed was about 130 mph, at 55/70 about 131 mph, not a lot of difference there. Wondering what speeds other players are getting. I'm hoping that there isn't some system senstive bug like there was in Shift 1 that's affecting grip level (in Shift 1 it also affected the bounce issue). Jeff, as a reference, my entering speed on the second corner at Willow is @139mph and i hold 132mph the rest of the corner. My setup does not work well for me at Nordschleife, tire pressures seem too high. It slid around way to much, which was one of problems i had not being able to finish the race, besides not being able to see the raceline and being dark and not knowing the track that well.
Post by dimitrikhoz on Apr 22, 2011 3:28:32 GMT
Post by dimitrikhoz on Apr 22, 2011 3:54:42 GMT
It looks like
the only tuning options that can make car significantly faster are downforce and right gear setup. (I wish we could programm ECU, tune engine and nitro...)
To much lesser extent: differential and ride hight. For some reason, tire pressures do not give any speed increase, they just change an amount of G-Force required for the tire to lose contact with the track surface. All other tuning options can just make cars more drivable. It will minimise number of errors made by the driver, which may lead to improvements in lap times.
Post by Steveo324xx on Jun 30, 2013 9:29:15 GMT
i m not 100% sure though but seems to be very slow even with tight tracks.... But we will se later:) Just take a look at autolog when we have played for a while André it's fast on tracks and I use a G27 racing wheel. Best braking car on there, may not be the quickest but it's awesome around corners.
