Post by TheGreenMonster (PC) on Apr 1, 2011 17:27:05 GMT
I figure out how to save multi-able tune specification per tracks per cars in the picture below, after saving a tune setup information you have to select a track or (track type) that the tune will applies too, if you don't select a track then your setup will not saved, With my Apollo I save it too all the (tracks) and and then restarted the game and it save my changes. So you can have a different setup per every track. not sure what the limit is.
Post by dimitrikhoz on Apr 3, 2011 3:50:44 GMT
Have you heared about Dr Pepper Edition Chevrolet Camaro SS?
Some say it is an insane car, suitable for darg and oval tracks. Highly recommended.
Is it much better than stock Camaro?
Post by Bandit (PC/PS3/4) on Apr 3, 2011 10:36:42 GMT
Well, i'm having tons of fun on the time attacks with my C997 Mk.1 Golf GTI!  You can throw this little bomb around very hard and sticks like flypaper hehe. Tried with the Zonda as well but that car is just insane! Have yet to try the Police Reventon though  Bandit
Post by rcgldr on Apr 3, 2011 12:05:09 GMT
Just getting started on car choices, what I plan to use, not sure if these are the best.
D class - Lotus Elise - 499 rating - hi flow filter, ceramic puck disc, quick change gears, race suspension, dual master cylinder, competion brakes
C class - Caterham - 999 rating - cold air intake, ceramic puck disc, race differential, quick change gears, race suspension, semi slick tires
C class - Audi R8 - 999 rating - engine swap, competition flywheel, race differential, quick change gears, race suspension, dual master cylinder, competion brakes
Not sure about the stats, I tried Lancer Evo IX and got it to a 6.xx handling rating, the highest of the 3 cars I tried, but it didn't handle better than a C class Elise or the C class Caterham I tested.
Post by aarog5606 on Apr 3, 2011 12:14:29 GMT
Jeff, if you get a chance, try the R8 4.2 as a Class C.
Post by rcgldr on Apr 3, 2011 13:29:04 GMT
Jeff, if you get a chance, try the R8 4.2 as a Class C. Added it to my previous post. Was thinking the semi slick tires would help more than that. The Caterham is a bit faster on tight tracks like Brands Hatch Indy, while the Audi R8 is faster on fast tracks like Road America. The Caterham's top speed is 152 at Road America, while the Audi was reaching 170 mph. Times were close with the Caterham at 2:13.9 and the Audi at 2:12.6. Don't remember the times at Brands Hatch Indy.
Post by Grnkjr0 on Apr 3, 2011 14:01:13 GMT
You could also try the Lexus IS F as a C999, and do an engine swap and just put upgrade parts on it. But be sure to change tuning, because the default tuning is terrible. Just put the slider bars into middle position as a starting point and it handles fine. It is fast on tracks were you can use those eight gears it has.
Post by rcgldr on Apr 3, 2011 22:00:13 GMT
You could also try the Lexus IS F as a C999, and do an engine swap and just put upgrade parts on it. But be sure to change tuning, because the default tuning is terrible. I haven't tried doing any tuning yet, just using the default tuning which is affecting my simple test results. If the activation key isn't stored in an offline only savefile, I could create one with a lot of money so that players wouldn't have to recreate the cars and setups already in the save and only add to it. Then based on feedback the "master" savefile could be updated. I did create a test savegame for Shift 1 along with a text setup guide. Would be nice to do the same for Shift 2. Note that such a savegame shouldn't be used online. In the case of Shift 1, initially there were no issue, but in patch 1.02 and perhaps after a change in the servers, players reported that the servers started grabbing offline lap times from the savefile, which polluted the players online stats. In the meantime, we'll just have to post the car, parts, and setup info in this or other threads, and manually duplicate the cars in our own savefiles.
Post by Jussi on Apr 4, 2011 4:18:30 GMT
Argh! I just noticed that every time I sell a car I've upgraded and tried on the track, I lose money. I've wasted hundreds of thousands of in game cash already.  Jussi
Post by Jussi on Apr 4, 2011 4:20:42 GMT
Post by rtxus (PC) on Apr 4, 2011 9:16:44 GMT
Hey ppl  Nice to see many of You in Shift 2 After playing some hours i have my first fav cars list: up to 499 Golf GTi (i think its faster than Elise) BMW 135i up to 999: fastest car (i think) Shelby Cobra R8 GTR 34 Honda S2000 Impreza up to 1499: Lambo LP560 RS4 (if you can drive with handbrake its faster than LP) Max cars: LP640 works (45.5xx on Silverstone national) Veyron works (fastest i guess, trioval 28:2xx, others look autolog records) ScionTC Bonus (impressive) I think in Shift 2 every car can be fast with the right upgrade/tuning, tuning is at least very important in S2... I drive it on normal/no assist online and elite/no assist offline but im still searching for the right controller setup (xbox pad) If you guys want setups, write it  Hope to cu all online. Marco
Post by skroting on Apr 4, 2011 20:04:35 GMT
Managed just now to build myself a decent B-class R8. After a race yesterday where I was left in the dust on Spa, I decided to take action. Using Brands Hatch as a test track, my improvement was around 4-5 seconds.
So, Audi R8. -Engine Swap -Cold air intake system -Competition spec flywheel -Race diff -Complete bigger turbo -Race coilover suspension -Dual master cylinders -Competition brakes -Semi-slick tires -Weight reduction
Perhaps I could have changed a part or two, but I just don't have the patience to test for hours.
Edit: And for setup, I just turned the steering lock down to 19 (I think), downforce at max (8) and final drive at lowest (0). I didn't bother checking to see if various other settings would be quicker.
What I however DID bother to check, was to see how it would be like to drive without ABS. I've been using this assists almost from the start, but now I don't know why. I can brake much later without it. I also tried Stability Control, but I didn't really like it. Maybe I'll use it if I do the Endurance races. This assists helps me keep the car on the road, but I feel it inhibits me a bit when I want to take the corners aggressively.
Post by Soul Traveller (PC, PS3) on Apr 5, 2011 10:55:29 GMT
Anyone able to send me a Dr.Pepper code?
Post by rcgldr on Apr 6, 2011 9:48:27 GMT
I'm just got to B class cars in career mode. Some one already mentioned using the R8 for C class, but I guess you can have 2 R8s?
After my C class comparason of 999 Caterham versus 999 R8, at Road America with default setups. I tried tuning the R8 with max downforce and zero final gear (max acceleration), but it ended up being slower at Road America, and the Caterham seems better for tracks like Brands Hatch.
I'm not playing online yet, as I'm working on an offline career mode save for myself. So I'm not ready to work on the setups yet.
Post by rtxus (PC) on Apr 6, 2011 10:06:14 GMT
Yep, You can buy all cars 10 times if You want. If youre looking for something faster, try out the shelby cobra...I play it online and noone was to date able to follow me  Actually online is not such good, You cannot set the handling/assists so You have allmost ppl who drive it with max aids just full throttling round the corners and crash You all the time... So as the fact that You cant even run two cars side by side without annoying crashes... Marco
